Mini Mini? |
Page 123 6> |
Hugo Biermann ![]() Young Croc ![]() ![]() Joined: 05 February 2005 Location: South Africa Status: Offline Points: 809 |
![]() ![]() ![]() ![]() ![]() Posted: 28 December 2008 at 12:51am |
After looking at youmy mans fighting and swearing about mini scoops for the past 2 years I finally got to playing around inside the given dimensions. Also took a gander at some of the photos Tek's got up here... I Probably f**ked up somewhere too
![]() Well... Aint anything special. 4 will go down to 38Hz with C18-650EL in HRESP. Parameters: S1 = 784.8 S2 = 1705.85 EXP = 145 Vtc = 70000 Atc = 2905 Single Plot: ![]() Plan: ![]() |
www.aggressiveaudio.co.za
Slightly modified. throats a bit bigger..
S1 = 828.4 ![]() Usable between 35Hz and 80Hz...... High pass 4 @ 30Hz |
levyte357 ![]() The 10,000 Points Club ![]() Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
TB thanks yet again for your contribution. But that driver seems to be yielding reflex cab SPL. ![]() |
boycey ![]() Old Croc ![]() ![]() Joined: 25 June 2006 Location: Manor House Status: Offline Points: 1612 |
even though i am a total noob at this and the whole scoop thing isn't really me... isn't the poor sensitivity down to the bits with zero expansion or the negative expansion towards the end of the "scoop" bit?
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
mobiele eenheid ![]() Old Croc ![]() Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
The low sensitivty simulated comes from the path length difference of 145 cm (not so wild guess). The actual path length difference is zero and should yield much better results both in SPL and flatness.
@Three-Bee: Tussen haakjes, moet er geen "w" achter jou?
Best regards Johan Edited by mobiele eenheid - 28 December 2008 at 1:40pm |
CHAMPION ![]() Old Croc ![]() Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3666 |
whats going on with all these MINI Bee scoops..!!
What are you trying to acheive ?
ASS & Shortman's have been proven.
Are you trying to design a mini based on the new Drivers ?? or just adding to the collection ?
Sticks n Stones
(SoundcreationaudiO) ![]() Registered User ![]() ![]() Joined: 09 October 2007 Location: Wales Status: Offline Points: 306 |
think he's just using his head, and having a go at something...
oky if thats the case...i could do with mini scoops which can play high 100-120hz having a punchy kick, and also play low 50hz ? max output volume.
Which mini will do this, small chamber i take it.
i can do with them rather than a double 18 cab
Three bee dont take it in a wrong way.
Good Investigation work..
![]() Edited by CHAMPION - 28 December 2008 at 5:28pm |
Sticks n Stones
nickyburnell ![]() Old Croc ![]() Joined: 06 February 2005 Status: Offline Points: 4410 |
Not so: Ass and Shortman can be as brilliant as you like but they are not DIY, this is a DIY forum called Speaker Plans after all.
Hapyy New Year
Here is the SPL Response with the SD18. The 1w response is the same and only about 1dB up on the 650EL.
Page 123 6> |
