Mini Mini? |
Page <1234 6> |
Hugo Biermann ![]() Young Croc ![]() ![]() Joined: 05 February 2005 Location: South Africa Status: Offline Points: 809 |
www.aggressiveaudio.co.za
http://img156.imageshack.us/img156/8126/minispleased18py0.jpg
mykey ![]() Old Croc ![]() Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
path length differance should be zero as mentioned
what you have done is the same as the schematic, that way would have bee slightly longer also. On a schematic, the mouth is behind the driver by 145+ the chamber depth
on a scoop, the front of the driver is level with the mouth
do you mind if I have a play around with this drawing?
![]() you do crack me up sometimes
Have fun with it Myk.
staiper ![]() Registered User ![]() ![]() Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
I have my version of large chamberer "mini" scoop (only in plans-newer built one)
It looks promising for it's category by simulations .. but I can't claim anything before RL test. Cabinet is nothing magic-revolutionary.. just plain simple mini-scoop. ..may post plans ..if I must.. if somebody is interested fot building/testing. ![]() |
Hugo Stubbie Scoop Version3 [SD18] :
Parameters: S1 = 866.4 S2 = 2074.8 EXP = 165.5 Vtc = 70000 Atc = 1349.6 ![]() ![]() |
CHAMPION ![]() Old Croc ![]() Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3660 |
Hi Stripe... I will be soon
Sticks n Stones
mobiele eenheid ![]() Old Croc ![]() Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Best regards
V4.....
S1 = 713 S2 = 2150 EXP = 165 Vtc = 60000 Atc = 1210 B&C 18NW100 B&C 18TBX100 ![]() ![]() |
Page <1234 6> |
