  New Posts New Posts RSS Feed - Mini Mini?
Mini Mini?
 Post Reply Post Reply Page  <12345 6>
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 1:35am
A Scoop and Kick pair over here now  >Direct Link To This Post
PS. Did I draw that Scoop right? Mykey? Anybody?
www.aggressiveaudio.co.za
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 12:28pm
very nice...ig then mid highs were the same width as all of the beloww, that would make a uniform stack, they way it chould be..your getting the hang of this !!  well done
Sticks n Stones
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 2:36pm
Originally posted by Three-Bee Three-Bee wrote:
V4.....
S1 = 713
S2 = 2150
EXP = 165
Vtc = 60000
Atc = 1210
B&C 18NW100
B&C 18TBX100
3B, that throat seems way to tight, and is pushing all the action right towards 50hz.
Larger throat and rear chamber is really what gives this little guy the oopmh.
So I would suggest at least 636mm cab width, with throat around 1000mm, and larger rear chamber.
Try Modelling,
S1=1000
S2=2150
EXP=165
Vtc=65000
Atc=1210
with
a)V18-1200,          // Flatten with eq to do 40-120
b)V18-1000,          // Sub monster, kick bin needed
c)PD1850,              // Sub monster, kick bin + restraints needed
d)Turbomax 1200
e)Turbomax 1000
f)Fane XB1200
Would also suggest double front baffle, and front extended to allow battens for grill that doesnt hit driver.
Also brace that forms part of the horn throat.
Edited by levyte357 - 07 January 2009 at 2:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 3:11pm
Cool Lev. Was going on the other mini outside dim's
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 3:20pm
one question...when you sim different speakers...did you change the vtc value regarding speaker dimension?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 3:26pm
Please finish this off ASAP 3B, its looking very serious already.
Nick "EL Cheapo" Burnell will like this, because it will work with Eminence Kappa/Sigma as well.
I "think" on average, 18" drivers swallow 8.5-13 litres, so real 75 litre rear chamber, should model as 65 litre inc driver pretty accurately.
Edited by levyte357 - 07 January 2009 at 3:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 4:29pm
@ Bitzo: I'm working on a 10L average on the 18's. You will have Lining in the chamber anyways so it will make a difference too..
V5:
http://img528.imageshack.us/img528/3996/miniv5ky7.png
http://img265.imageshack.us/img265/4620/v5inputum7.png
http://img74.imageshack.us/img74/8661/v5splma0.png
Feel free to adjust the plans as you guys like, hey. Anything to make the thing perform the way it should....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 4:30pm
That 70Degree should be 80!
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 8:02pm
"Nick "EL Cheapo" Burnell will like this, because it will work with Eminence Kappa/Sigma as well."
:) Two Omega Pros waiting.
 Am I right is saying that the Soundbarrier Minis look like they just have a slope rather than curved scoop?
Edited by nickyburnell - 07 January 2009 at 8:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 11:22pm
Think we're losing it a bit there 3B.
Take a look at the Bull X scoop, to see what kind of proportions are possible.
You'll also see the brace forming part of the throat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2009 at 12:09am
So, you want something that looks like this inside? ]more or less]
"You'll also see the brace forming part of the throat."
> I see a brace in the throat, not part of the throat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2009 at 12:57am
Lev, Are you comparing this to other sh*t yourself though? If you want bracing between the panels you can add whatever you want... This is the Bull-X and my V5 Mini with V18-1200:
http://img509.imageshack.us/img509/4923/62007317qb8.png
