Mini scoop driver choice |
4bloc ![]() New Member ![]() ![]() Joined: 01 October 2020 Location: Milwaukee, wi Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 25 October 2020 at 5:27pm |
Hey all! Ive got 2 mk1 mini scoops from the 18”
Mini scooper plan on freespeakerplans (i believe its the mk1 staiper bins? ) Currently looking for the best modern driver options, looking for something high power handling. The sound will be used for dub/ bass oriented electronic music mostly and looking for something easily accessible in USA! Edited by 4bloc - 25 October 2020 at 5:52pm |
njw ![]() Old Croc ![]() ![]() Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2534 |
Can you get hold of the Void V18-1000 where you are?
FOO ![]() Young Croc ![]() ![]() Joined: 23 December 2018 Location: Denmark Status: Offline Points: 668 |
I have just aquired four Staiper MS-18 mk2. Would v18-1000 be a good match in them also? Or Maybe some more modern drivers would be more fun?
Not super easily on the void stuff. Are any b&c, eminence, or beyma drivers up to the task potentially? Something in their high power ranges?
bob4 ![]() Old Croc ![]() ![]() Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1763 |
if you have more than 248 mm space in the backchamber, i would try 18ds115
![]() will need a lot of juice though, but has low qts (0,2) and high linear excursion.
