Mini Scoop EQ Settings |
Casual1977
Registered User Joined: 24 October 2022 Location: Barnsley Status: Offline Points: 22 |
Posted: 04 November 2022 at 3:22pm |
Could anyone tell me any general EQ settings that would be good for use with mini scoops? I will be running them from 38Hz to 90Hz with 24dB L-R slope. Are there any particular frequencies that should be boosted and by how many dB to get optimal performance out of them?
levyte357-
This question should really be in Scoop Forum. To stop this site, from being liberally sprinkled, with Scoop posts, all over the place, I requested the creation of the Scoop Forum, well over 10x years ago. Maybe send message to Admin, to move it there. Also try reading MS18 thread in Scoop Forum, the designer pposted plans for this cab here, long time ago. |
Casual1977
Sorry.... I'm a self proclaimed 'newbie' so thought this would be the best section. I will be sure to ask any future enquiries in the appropriate forum.
njw
I know I run a low shelf eq on mine to bring out the very low notes but what the settings are exactly I can't remember! I'll be at the venue they're in tomorrow afternoon so will have a look and get back to you... :)
Meat Substitute
Registered User Joined: 10 July 2020 Status: Offline Points: 79 |
I like the following. I'm not any kind of pro dude though. +6dB @ 40Hz, Q=2 low cut 48dB/8ve @30Hz. |
hi grade
Young Croc Joined: 18 June 2008 Location: manchester Status: Offline Points: 965 |
Depends on your set up 4 way 3 way or 2 way reflex or horns on top and size of the room also what amps and speakers you are using !
njw
I'm in front of the amp rack now, the settings are +6db <50hz low shelf with a an 18db slope.
turbo7
Registered User Joined: 15 March 2009 Status: Offline Points: 233 |
Just remember, EQ boost of +3dB is a doubling in power at that certain frequency, excursion will be 50% higher.
