Mini Scoops - Reality check |
Page <1 1011121314 15> |
wires ![]() Young Croc ![]() Joined: 21 May 2009 Status: Offline Points: 1354 |
Astoria had an ASS system, End of the 90's but remember going in there and it being extremely weighty on the bass end lol. Were these scoops installed?
Sounded excellent, phat and clear, even though the headliner was mixed so loud I was deaf for a couple of days afterwards... still got the ticket stubs for that gig somewhere. I think they replaced that system later on for something 'better', last band I saw there before it's closer didn't have the same experience although still good. |
nickyburnell ![]() Old Croc ![]() Joined: 06 February 2005 Status: Offline Points: 4410 |
Should add that in that 4 way system I built I did a PA for a wedding in a barn. After we messed around and ran one stack with 2 x EX18bhp and omitted the minis. The rock/60's stuff that was so bad before came to life. Hence my (IMHO) conclusions
Astoria I think? Different times, even the house music was 55 up and knowing Tony the kick section was probably as well designed as the rest and doing all the work. Yeah, vocals through horn loaded cabs doing other frequencies, thought that was left behind with 15" W bins with tweeters, Marahall, Simms Watts....... Off subject, my hate of F218 is (unfairly) based on two or four in small clubs. Do they couple and go low enough in stacks of three? Is that the secret? Must try and hear in right environment, he is British after all.. |
Diaz ![]() Registered User ![]() ![]() Joined: 09 November 2011 Location: SBG | Austria Status: Offline Points: 36 |
Thanks for the suggestion. What i see is that the MS46 comes with a smaller chamber and also smaller horn mouth than the MS18 MK2. The SPL graph also says that it has a higher tuning than the MK2. I also would need a Driver with a lower Qts. The Oberton NXB1600 has quite high Qts (~0.30) and therefore i dont think it would fit? Am I right? To your MS18 Mk2, ES18 Stack; how you set the filters? Did the Minis play up till ~80 or did you HPF it lower? How did it in comparison to other Stacks like e.g. Hogs or full Scoops? Did you ever had the chance to compare in a dance? Could you keep up? |
SUBSISTENCE Soundsystem https://t.me/subsistencesoundsystem
Mini Scoop Soundsystems Group: https://www.facebook.com/groups/749452582177469/ |
80hz yes.
Outside of, "rolling bass" type music the minis were wasted. They also to me all sound horrid over 90/100, but then I don't like a reflex over 100 either. Maybe I was jaded, but the do in a barn encompassed a lot of different types of music. Knock up a prototype and try, only a few quids worth of MDF. You may fine it suits you. I've had a lot of minis, but I'm not really active nowadays. My angle on trying the link for myself is that there is a ton of new dance that now has real 40hz and I've never stood in front of a single cab that's not a reflex that doesn't lose it down low except the MS18 mk1 with the V1200 (run flat that is, no pre). I have never heard Shortman though. Still need kicks though, which brings us back to the PA argument, and round we go again. For me PA needs sub to 100ish in one cab and as pointed out no vocals in the kick range for live. Just like every touring system nowadays Build and try, only way, I did, didn't like it, you may disagree............ PS, I secretly love your T18 pic still my favorite for 88/95 house music in a block of 4 with top two upside down :) I have an idea. next time there is a traditional sound check with scoopist system chuck some rock, 60's, RAP, techno and a load of other stuff through it and report back folks, the PA world might be wrong........wouldn't be the first time. Regards and respect to all. |
So; we "tried" and made a "Measurement" for the MS18 mk2 with the Oberton 18NXB1600 and the Precision Devices PD.1851.
As it had -17° outside we decided not to make it outdoors. And as you cant make a calibrated Measurement inside a Room we decided just to measure near-field in front of the Horn vs. in front of the Speaker. In the Graphs below you see the green line for the Speaker and the red line for the horn measurement. What was surprising was that the Oberton and the PD had nearly the exact same curve line at the measurements but the Sound and the efficiency was very different! The Oberton 18NXB1600 sounded more harsh/rough and had a lot pressure. The PD.1851 played more harmonic/melodic with more resolution but had less pressure. Probably its because of the heavier cone of the Oberton but when we pushed it to xmax limit you cant hardly breath in front of the Mini and even with rubber feet mounted it was moving around the floor. With the PD this effect was missing. So to make a recommendation i would use the PD more for full range purpose in the MK2 (30-90) and the Oberton more for Infra purpose (30-65) when tonality does not count as much as pure SPL pressure. What was also surprising was the fact that despite the simulation showed a peak around 45Hz the measurement has a peak at 38Hz and the Mini played well till 30Hz with a quite manageable excursion. We have been more worried about the occurring excursion around 55Hz as its more in the range which is hit by music more often. You can see the white dot we drew on the cone to recognise the excursion. Looking forward to your thoughts about tuning the MK2 and how we could curtail the excursion at 55Hz. ![]() Graphs are NOT with equal SPL! Green= in front of Speaker (should be seen ~ 3-5db up), Red= in front of Horn ![]() Edited by Diaz - 24 January 2017 at 6:47pm |
luton_soundman ![]() Old Croc ![]() ![]() Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4276 |
We could have told you that the 51 wouldnt have worked in this cab and saved you the trouble
Thank you, would have been nice.
I was just interested how big the difference is and how the lighter cone effects the tonality. was amazing to hear this. My friend who done the measurement also passed me a plot from a measurement we did years ago with a Hog Scoop loaded with an Oberton 18XB1500 but with magnet outside (!) as we cut the hole too small... What that shows is not such a big difference in sub peak than the Mini has. the Hog Scoop went with ~35Hz the Minis with ~38Hz... Btw. still open for input concerning the tuning ;) ![]() Edited by Diaz - 24 January 2017 at 7:10pm |
B_Bender ![]() Registered User ![]() Joined: 28 October 2016 Location: Surrey Status: Offline Points: 118 |
You can't even use a mic stand for the measurement?
Your test is totally invalid - laying the mic on the horn mouth. Seriously?!?!?!
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10703 |
Er. That is actually how you measure bass, to avoid floor bounce. |
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7306 |
but with a scoop... (or eh port assisted whatever was decided...) will you not be somewhat missing the measurment of the driver / direct radiating element? (measuring as shown in the photo rather than at a distance of 1M or so)
Yes, I know about groundplane measurement etc - the vibration through the cab will give you unwanted mechanical readings though. It needs to be on a stand!
