  New Posts New Posts RSS Feed - 'Mini Soundsystem' Questions..
darkmatter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2010 at 5:00pm
Pure guesswork but I don't think they were placed side by side for testing? I've seen positive reports for that sort of layout using tangband drivers elsewhere (from people who didn't own beastly 20hz horns also) so hopefully nothing to worry about :)
davey t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey t Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2010 at 7:12pm
If you scale down a bass horn eg a  superscooper, then the horn wont be long enough to reproduce any low frequencys and you will get honky nonsense. You need something with a lots of folds to make up the long horn length... as demonstrated above
mashed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashed Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2010 at 9:27pm
Thanks all !
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 2:47am
"The guy didn't remove or short out his huge TH enclosures when testing the smaller ones, so in effect he was listening to 4 cabs, not 2! "
Hmm, it plays 104dB/1W/1M, I'd say that was remarkable too for a 35L box!
Edited by _djk_ - 23 July 2010 at 2:22am
djk
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 10:26am
Cor, never seen that simmed before. Thats probably better for in terms of cab size and input vs SPL compared to a lot of 15 and even some 18 reflexes although they probably suffer less power compression.
Strange Daze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strange Daze Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 10:43am
Edited by Strange Daze - 22 July 2010 at 10:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strange Daze Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 10:45am
In regards to a mini-scoop...I have a friend that just scaled down the eminence design to fit a 6£ driver. He wanted it for his car. I must say, as long as you’re not expecting pro audio results, and are just having a giggle….there’s nothing wrong with it at all.
Eminence to have a 12” scoop design though, which I’ve considered building for my home DJ workstation. A pair of 12” scoops to go under my home 12-6-1” - and I’d be very happy. (yes my neighbours are old and deaf lol)
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 12:59pm
40hz is achievable from a 8'' scoop
subbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 3:48pm
prove it .. with plans Big smileTongue
jeddere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeddere Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 5:33pm
Recently finished building a transmission line for home use.
Designed to play 40 Hz up to around 300 Hz, measured fairly flat when set-up outside.
The cone excursion doesn't rise up steeply at low frequencies so there's no need for a high pass filter for home usage.
Driver is Monacor SPH 165-CP
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 5:58pm
That looks great. Nice design.
LjudLahger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LjudLahger Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2010 at 8:08pm
Thumbs Up
