Mini system run off small generators |
xXxSOLOxXx
New Member Joined: 13 June 2019 Status: Offline Points: 5 |
Posted: 13 June 2019 at 2:27pm |
hi all, I am wanting to build a system that runs off 2x950w generators that I have already acquired for parties. Would mainly be playing dnb tek hard trance minimal ect obviously this is nit a lot of power but I would only need it for 30 people (40 max) would ideally like it to be a 3 way system and easy enough to chick in a car. Bare in mind some low power led lights, a laser and a laptop would also be powered off these generators. I don’t really know where to start so please could you all help me out
Teadub
Registered User Joined: 13 April 2019 Location: Highlamds Status: Offline Points: 29 |
You may be a bit hard pushed with a pair of 950w gennies but a pair of active 12" + 1 speaker on a stick type things may work for you and is a nice simple solution. Admittedly won't do much justice to the lower frequencies. Another option would be to use one generator to power a small sub (something like a tham 12 would offer decent efficiency) and the other generaror to power a single top either active or passive and to run your lights etc. Although a larger genny at least for your bass would be handy.
