Minidrive programming - help required |
Post Reply | Page 12> |
Safetyman
Young Croc Joined: 08 February 2009 Location: Brighton, East Sussex Status: Offline Points: 555 |
Posted: 02 October 2009 at 8:56pm |
Anyone in the Sussex area know how to programme these, please ?
My 334 is proving difficult to get to grips with for eq and crossover settings. Willing to pay the going rate for the time.... Cheers |
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4226 |
Just download the FDS 336/334 manual from the BSS website and it is really easy to follow.
Safetyman
Thanks Robbo.
I have already done that some time ago, but just cannot get the crossover and filters to work. |
Robbo
May be worth having a word with Chilli(Rich)---I think that he is somewhere down your neck of the woods and he is a pretty clued up and helpful member.
ceharden
I'm kind of nearby. The minidrive is pretty straightforward though, I'm sure we can talk you through it on here. Can you be more specific about the problem? Can you see the crossover settings and edit them?
Safetyman
Hi Guys,
Thanks for the offers of help, much appreciated. I have set-up the basics for a four box system, 2 tops and 2 bins running in stereo with Linkwitz-Riley filtration, but cannot see how to get in and set a 120 hz crossover between the two. Also, I need to get in and set a 5db cut at 315 hz for the tops in the outputs. These are all recommended by the manufacturer( HZ ) with the crossover at 120 as a starting point. Cheers |
TRE4U2NV
Old Croc Joined: 21 May 2005 Location: home Status: Offline Points: 2592 |
depress the big black thumbwheel and then use the other up down left right button to scroll to desired function then adjust as you please
ps never used a mini drive but asume its set up like the omnidrives
ceharden
Sorry, but I'm still not sure exactly where you're having trouble. Saying you've set up Linkwitz-Riley filters suggests you've made it to the crossover settings but you say you can't get in to edit them.
You can get to the settings for each output by either pressing the gain trim next to that output or by pressing the large rotary encoder which will cycle through them. If you have the unit in stereo mode (in the utilities menu) you will only need to set up two of the output channels because they'll be ganged together. Once you're editing an output you can navigate using the 4 way pad. Lo Freq is the lower crossover for an output so for the bins that might be 40Hz. Hi Freq is the upper crossover so for the bins set that to 120Hz. For the EQ, it's at one end of the parameters for the outputs. When it says Eq1S on the left you are editing the EQ type for EQ number one. Set that to Bell. Go one parameter to the left I think using the pad and you'll get to set the frequency, next one will be gain and then the next one will be bandwidth. If you move another position it'll insert a second EQ so you'll probably get Eq2S which will be the EQ type for EQ number 2. Are we getting anywhere? Manual is: http://www.bssaudio.com/product_downloads/User_Manuals/fds336Tum.pdf |
Robbo
Is it all fully unlocked?
Safetyman
Hey Chris,
it seems to have worked fairly well apart from the bandwidth. What should that be set to, please ? Where are you based on South Coast , as a matter of interest ? Cheers PS It was partially locked-out Robbo, thanks |
ceharden
Bandwidth is basically the inverse of Q. It's done in octaves.
A bandwidth of 1 is one octave so if you have your EQ at 500Hz, it'll be roughly 500Hz wide (eg 250-750Hz). A slider on a graphic is 1/3 of an octave so if you want to do an EQ that wide, set it to about 0.3. I'm in Southampton. |
demanddeepbass
Young Croc Joined: 14 June 2006 Location: London Status: Offline Points: 516 |
If you're a bit computery the easiest way to set these up is using the London Architect software available off the BSS website. It gives a nice pictorial diagram of what's going on and is far less cryptic than the front panel controls. You'll need a null moden cable and a computer with a serial port.
"These amps go up to 11"
