mitre angles in the mt122 flare |
Post Reply | Page <12 |
pope
Registered User Joined: 03 February 2006 Location: Sweden Status: Offline Points: 121 |
I think I have an idea how to figure this out...
The long flare is 12°. If you put the short flare vertical and in a straight line with the long flare the bottom angle will be 0° but if you put the short flare vertical and 90° to the long flare the angle will be 12°
So if you turn the flare closest to the driver 12° the angle at the bottom will be 12/90*12=1,6° The angle for the outer flare turns 24° and will be 24/90*12=3,2° This is theori! I hope it is correct in real to Edited by pope - 20 December 2006 at 2:46pm |
