  New Posts New Posts RSS Feed - Modded X15
Modded X15
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2013 at 7:34pm
I would only apply that correction to the inner end of the port, the outer end of the port has less extension from the sides of the cabinet to start with.
David.
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2013 at 9:32pm
Whilst it is perfectly possible to run a 15" and a suitable 1" together it is the 15 that needs to be chosen with extreme care if you want a nice open mid section.
Tony
alovan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alovan Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2013 at 6:33am
In this case, what TS parameters are important? Qms, Le, BL and Vas?
Edited by alovan - 24 May 2013 at 6:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2013 at 3:18pm
Never actually compared the T/S parameters as I know what I am looking for anyway.
They tend to have smaller voice coils 63mm or 76mm, smallish xmax and low mass (goes with the small voice coil and xmax).
In all honesty the best way is still to listen if you can as even drivers with similar parameters can sound totally different.
Sometimes personal recommendation from a person you trust is the best way to go.
Tony
Edited by Tony Wilkes - 24 May 2013 at 3:19pm
mans1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2013 at 1:45pm
This maybe of some help....?
Trap box port calculator 2nd one down.
Edited by mans1000 - 25 May 2013 at 1:46pm
"The earth provides enough to satisfy every mans needs...but not every mans greed."
Post Options Post Options   Thanks (0) Thanks(0)   Quote alovan Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2013 at 11:05pm
Thank you guys for the wise comments, helped a lot!
