  New Posts New Posts RSS Feed - Modified 186 horn build pics - more added 10/06/09
 Post Reply Post Reply Page  <12345 6>
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2009 at 12:55am
Nice work :) These sort of step by step picture guides are great stuff for the newbiesThumbs Up
jaya000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaya000 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2009 at 5:37am
I want to know how u hv calculated S1?
The S1 for 636 wide box : 11cms x 60cms = 660 sq.cms.
The S1 for 536 wide box : 11 cms. x 50cms = 550 sq.cms.
Wrighty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2009 at 10:35am
It depends where you take the throat to be. There was a lot of debate on it at the time and I went with it being at the edge of the driver nearest to the throat, so take the cross sectional area at that point.
All handles routed in these bins now, plus the hi-mid cabs. Put the final bits of filler in yesterday but the weather has taken a turn for the worse, so back at work today... A quick sand, wipe off and then it's Aldcroft time :D
ALL YOUR BASS ARE BELONG TO US.
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2009 at 1:38pm
I discovered that the throat in this kind of horn throat arrangment is somewhere between the edge and dust cap of the cone. If the speaker baffle and the opposing baffle are taken into consideration and speaker & its cutout are ignored, the throat just keeps expanding, but if you take the air volume in the cutout and in the cone into consideration, there will be a point where throat chamber is at its biggest (somewhere around the middle of the cone), and when you  move towards the horn, closer the cone's edge, the area starts to get smaller until you hit the point where it starts to get bigger again because the cone area starts to play smaller role and the speaker baffle starts to take over...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2009 at 8:28pm
Ok, yet more pics...
Hi-mids before painting. 8PE21 and DE250, both horn loaded. These sit above direct radiating single 15" cabs, which in turn sit on a pair of the 186 horns.
Access panel during painting.
18LW1400 installed. I know you can see the dimples where the filler is... Unfortunately it all sank when I put the paint on. Won't be using that filler again!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2009 at 10:57pm
Looking quality.. :)
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 3:12pm
 Thumbs Up
**Heavy Weight-Line**
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 3:28pm
Will have the whole rig out on Saturday, for Tavistock Summer Solstice 09 Live Music & Beer Festival :D
Just hoping for some sun and no rain this year...
evolution rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote evolution rob Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 7:02pm
Quality Build Mate Good Effort!!
mace.ben View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mace.ben Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2009 at 6:37pm
nice one.
Strange Daze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strange Daze Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 12:45pm
serious.
Nicelly done!! :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 12:48pm
Cheers guys :)
In case you haven't already seen them, there are pics of the rig in action here:
http://forum.speakerplans.com/show-off-your-sound-system_topic2179_post277461.html#277461
