modified mt122 |
djslacka
Registered User Joined: 12 March 2009 Status: Offline Points: 264 |
Posted: 02 April 2009 at 11:45am |
hi, i have seen on here that a few people have taken the mt122 plan and made it as 3 seperate boxes, one for the tweeter and 2 for the subs. would this work if you just made the box for the sub on its own? i have seen a few in pics and am thinking of building some, has anyone on here done this and how do they sound?
cheers
rob
Rockin
Young Croc Joined: 02 April 2007 Location: Rotherham Status: Offline Points: 737 |
The lower part of the cab arent subs. They are mid range which is very different. You can split the box up from the original design with no ill effects. A lot easier to carry thats for sure. They sounnd the dogs imo. Ive got a pair of MT's with seperate tops and the projection they have is awesome. Not suited to very small rooms or if you need wide dispersion
trebor
Registered User Joined: 11 November 2008 Status: Offline Points: 304 |
@Rockin: Have you built MT120s? (see http://www.speakerplans.com/forum/forum_posts.asp?TID=24914&PID=252608&title=mt121-build-or-start-of#252608 )
If so I'd be interested in seeing and hearing them! trebor |
