  New Posts New Posts RSS Feed - monacor advantage system
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2005 at 6:39pm
Originally posted by tb_mike tb_mike wrote:
The sub is all BP6 super 55hz peak
funny you should say that. i have just had the windows machine out to
have a furtle with bass box pro. the spec driver modelled in that
enclosure was indeed all 55 Hz peak. my fane classics come out as a
similar shape but with a more dramatic peak followed by a flatter shelf.
i want to keep the enclosure size if possible; the computer came up with
a taller design with the same footprint to get a nice flat shelf from 50 to
100 Hz with the fanes, nearly 1m tall. the challenge now is playing with
the port tuning to get as close as possible in that tiddly package. it might
well require trying twin ported chamber tuning.
all good stuff, james.
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2005 at 7:57pm
Originally posted by james, ind.st james, ind.st wrote:
"big learning curve" are not inspiring words to be hearing at this point in
my life. AJHorn sounds worth a go, but it is off-axis response that
particularly concerns me here.
what i need to do i think is determine the frequency range the 8" will be
playing. i like the idea of the 2" above it playing to around 2k, or just
before the sound gets a bit metallic, but will the (active) crossover point
with the 12" be determined by the power handling of the 8" horn at lower
frequencies? power from the 12" to match can be dialed in to suit.
objectives are becoming clearer for this (ambitious) system design, and
i'm finding that is really helping my understanding of how to evaluate the
specification of various components.
i am working towards an ultra-small footprint, high portability, visually
imposing stack capable of high spl in small venues and adequate levels
for outdoor general public address and sound reinforcement. horn mid
and top section to have excellent useable horizontal dispersion to <-10
dB @ 90 degrees across the whole frequency range.
excellent separation and clarity in vocal ranges are desired functions,
resolution of acoustic instruments and percussion with a bright but not
over imposing sound would be nice.
the bass section does not need the brutal front and projection of a horn
system. for those events i have my other system. high bass will need to
match system power from 80-90 Hz (how high should i tune the reflex
response of this element in order to preserve low level full range
operation?). ultra compact subs to be optimised for high fidelity with
useful output down as low as practicable. this will be at the expense of
transient response, for hard dance music in a small venue the 12" must
take care of the punch.
performance optimisation will lean towards fidelity over spl.
i love this, the more i look (and ask) the more i see, the more i see, the
less i understand. james.
Build a ~400hz conical midhorn and dont worry about dispersion,just copy others like Graeme or Adrian.
the 8" on horn will be loaded to near 400hz,excursion will be minimal,thermal power handling will be the limitation,but because below this theres a 12" direct radiator-the limitation will be the 12"
12" tuning will simply depend on its parameters. What F3 do you desire?Make the response flat to ~70hz etc-this then can form part of the xover function to the subwoofers.
http://www.centauriaudio.com.au/diy
http://www.geocities.com/adrian_mack/homepage.html
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2005 at 5:13am
"The sub is all BP6 super 55hz peak"
The drawings show a BP4 with a peak at 65hz and only 85dB/W at 40hz.
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2005 at 10:32am
having just found the cursor tool on bass box pro, it is indeed 65 Hz. not
good. i have spent ages trying to tune the box lower and am coming to
the realisation that it is too small for that. the Vas of my fanes is quite a
lot more at 444 litres against 333 for the monacors which i don't suppose
helps. firstly, can flat response be managed at reduced output in a box
this small?
then i tried isobaric loading in a 184 sub. mild port tuning rendered +/-
1 dB from 40-110 Hz. not loud, but looking smooth. the 184 is slightly
smaller than 2 advantage subs (good for transport, bad for carrying, less
stacking height) but isobaric loading?
clamshelling drivers has always held a fascination for me, but i know you
do it at the expense of output. better lf response with tighter cone control
are the potential rewards if i remember correctly.
if i'm going to put 2 18" drivers into a box 864 x 615 x 536, that might
not be the best way to do it. imagine an infrabass type arrangement, or
triple chamber bandpass.
the reduced height seriously raises the issue of low mid projection. in
light of that excellent conical horn article (i had assumed tractrix would
be necessary for dispersion) the top might need a bit of layout
modification with the 8" horn going up top. problem then is, where do
you put the slot?
ha! i've also just noticed you can't fit isobaric driver loading in the 184!
back to the drawing board...
james.
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2005 at 3:58pm
i really should have spent today doing other stuff, but you can fit
isobaric driver loading in the 184 shell if you tilt the baffle. by then
making the port a single shelf with flared ends you retain the
performance. i wish i could host pictures so i could put a sketch up but
i'm sure you get the idea.
the bass box plots look excellent though, except for perhaps a quite loud
broadband harmonic resonance on one of the ports they are really
encouraging. really smooth and even from 40 to 110 Hz.
i find myself warming to the idea. the box is actually still smaller and
lighter than the top, breaking the subs down isn't essential although it
was useful. output level becomes an issue, building another is not the
preferred option as amp requirements rocket. and so does system size.
the 12" won't struggle to keep up with it. i don't think so anyway, the shift
is back to dispersion and mid top layout/tuning.
james.
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2005 at 4:15pm
There is a trick to tame those becasue they result in really nasty resonances. Drill holes in the port at the presure maximum of the first mode (might require some experimentation to get in just right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2005 at 8:37pm
If you live in the USA I have a design for the Eminence 15257, a $58 speaker designed as a sub for Baldwin Organ Co.
In a BP4 24"X24"X36" (external using 3/4" plywood) it is 102dB/2.83V/1M using BassBox Pro. 40hz~100hz, 124dB with only a 150W/8R rated amplifier.
Edited by _djk_
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2005 at 9:41pm
as it happens the drivers in question for this project are the fane classic
kc18-300c, by virtue of the fact that there is a large pile of them
gathering dust in my man's store so the price is right. $58 is good, as are
those dimensions, but i live in the uk.
600 W into the pending isobaric design is looking at producing around
122 dB at 1 m flat from 40-110 Hz. the rcf 12" in the top with Fb 70 Hz
will do that without a crossover when driven with 250 W, crossed with the
subs at 80-105 even response will be achieved with less power still. so
far so good. assuming the port resonances can be tamed during the box
and port tweaking phase, i think i have found my subwoofer element.
it seems odd to sacrifice 124 dB output at 1 m from only 300 W from my
best working of a fane in the single compact box, but that is still only at
65 Hz and by 40 you are 10 dB down. reflex bandpass things don't get
more lf from grouping (?) so if i remember the trick is to tune low.
now i see that the standard monacor sub design is all about output for
size. i want fidelity and extension, if anything just to see what the fuss is
all about.
potential problem. dod active crossover proposed can offer lowest
crossover point of 750 Hz for the mid-high. i was thinking of ~400-2k
for the 8" mid horn. this will determine the demands put upon the 2"
from a passive crossover perspective. the rcf has good rich tone up to
1.5k though, would 750 Hz crossover work?
james.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2005 at 5:57pm
Quote
Oops.
Quote reflex bandpass things don't get
While looking at the SPL graph,imagine the graph simply of the same shape but in parallel and of higher magnitude.
Isobaric
50hz F3 is probably ok for most people.
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2005 at 7:36am
as vaguely stated elsewhere i have realised that i need to do some
subjective listening tests. i can't ask people here to tell me if a power
trade of for lf response is right for me, but you can keep me in check with
regards the laws of physics and sound reproduction.
i have two workings of the same 150 litre box. one is a slight
improvement on 65-100 Hz response but basically the same as the
monacor box, the other is less output but f3 of 40 Hz. when i have time
they can be prototyped and then i shall report my experiences and
findings.
in the meantime, less dreaming, more woodwork.
james.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2005 at 12:40am
Dont go crazy with two choices when the graphs are so similar the difference is hardly 3dB. 50hz is 'enough for most' as it captures most fundamentals of normal music. Id normally want a F3 of 42hz if possible
