Most sensitive driver for 100 Hz to 1K |
Post Reply | Page 12> |
Author | ||||
TMH Music
Young Croc Joined: 07 April 2011 Location: London Status: Offline Points: 637 |
Posted: 18 March 2019 at 9:57am |
Hi folks, so I’m just playing around with a little project at the moment, for an off the grid system. Won’t have more than 100 watts per mid/top. What would you folks recommend.
Nothing is foolproof because fools are so ingenious
corell
Young Croc Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1161 |
this would probably be a low qes, high EBP, high VAS 15" in big ported enclosure.
Earplug
Yes, I´d look for something (oldish) from JBL or EV - or even an old ATC, eg PA75, etc. All with good SPL and response. |
jbl_man
If you can find any, JBL E130 15"...will give a whopping 105db/w/m. i
dont know of any other driver this sensitive, other than,as Earplug
says, the ATC 12" monster mid ,M1230, which was 108db/w/m.
Due to rarity nowdays ,both will be quite expensive. |
meister_gue
Registered User Joined: 01 October 2010 Location: Austria Status: Offline Points: 62 |
Beyma´s 12/15P80Nd are pretty efficient
Fracture_clinic
Registered User Joined: 01 November 2018 Location: Norwich Status: Offline Points: 113 |
Beyma 12MI100 is 5.1% I came across another somewhere over 6% but cant remember what it is, I'll have a look and get back if I find it. |
Fracture_clinic
Scratch that... it's a 450w driver |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
So? I doubt you'll give it more than 100w anyway.
Fracture_clinic
Why do you doubt that? |
SamV
Once you've high passed to something suitable, there isn't much power left to balance it all, and while you might try to get 130db outta it, chances are you're using more than one cab with less actual power per cab.
TMH Music
Actually, this was one of the drivers that stood out for me! I know its a 450w driver, but I see no reason why it couldn't do the biz in the right cabinet, fed 100w, or am i missing something?
Fracture_clinic
Nah, it was me.. I missed the detail a little, in that I though it HAD to be a 100w driver to fit your critera. I never did find that 6+% driver. Maybe I was dreaming. |
