Motion triggered audio |
Post Reply | Page <123 |
Author | ||||
mini-mad
#cough# pictures or it never happened #cough#
Racks&Stacks
Registered User Joined: 10 February 2006 Location: Germany Status: Offline Points: 204 |
so, 5 quid for one setup, which will be fiddly when it comes to aligning the laser, vs less than 2 and all one has to do is aim it down
SouthwestCNC
Yes more work but you could do some cool stuff with lasers sensors, like activate something when a hand it placed through a hole for example. Pir you kinda just hope that it triggers when you want it to. Never tried a £2 pir seems a bit cheap. Edited by SouthwestCNC - 08 September 2017 at 4:53pm |
4D
Awaiting two resistors |
4D
Well its up and running... audio quality is good for such a small
device. The pir needs a decent voltage to operate properly and a
few idiosyncrasies on loop length pir release timing & retrigger to dial in and then fit it all in a discrete box but so far so
good..
Edited by 4D - 10 September 2017 at 1:44pm |
odc04r
Looks good, should be not too much trouble to modify the code to get what you want out of the PIR with regards to sensitivity.
