Mounting amps on the rear brackets |
Hvedstrup
Registered User Joined: 30 October 2009 Status: Offline Points: 413 |
Posted: 13 January 2017 at 7:25am |
Hi all
If a want to Mount my Powersoft K6 so they are hanging in free air what brackets do i get to use the rear mounts on the amp?
B_Bender
Registered User Joined: 28 October 2016 Location: Surrey Status: Offline Points: 118 |
you probably have to make one as they're all different.
Or get an amp rack custom made with the right angle rack strip. Powersoft are designed not to need free air above or below, they have very good cooling. You're better off taking the time to clean the filters often, and install a fan or four in the back of your amp rack.
MattStolton
Rail support rails/slides are commonly used in IT server racks, makes sliding heavey gear in and out a doddle. Most rack mount UPSs come with them as standard extras.
Simply a piece of L angle which attaches to front and back rail. Unit slides in on rail, and do up front bolts. Some variations, but pretty much it. We did a lot of massive 100V line PA racks, in Schroff Racks, and slides made service a breeze. The clever ones don't loose a "u" under the slide, cheapo means you have to leave 1U gap to allow for the slide, but a 1U vent panel is never a bad thing, even with decent cooling design of a powersoft.
Hvedstrup
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
It's made a lot easier if the rack only has 1 make / model of amp - so a few K10's or similar is easy.
You just need to fit the rack strip that will take rack nuts on the side, at 90 degrees to the front / back. Like this stuff: If you have a shock mounted rack with the steel frame, things become a bit more tricky. Or if you want to secure amps of varying depths in the same rack. The installation racks we use have slots to allow you to vary the depth of the front and back strips to suit; piece of piss.
