  New Posts New Posts RSS Feed - Moving on from DB Fortyline - HK Linear?
mattd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattd Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2023 at 5:05pm
Thanks RCF is on the list :) open to suggestions of what to look for.
Certainly would he happy with an RCF system. I also see DB tech (esp Fortyline) as cheap RCF but with poorly made boxes!
Interesting no one has backed the HK actually! I'll keep researching :)
Edited by mattd - 06 November 2023 at 5:08pm
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2023 at 5:01am
I haven't heard anything HK Audio stuff used in anger over a longer periode of time. Only a short demo of a Contour Array setup. 3 subs and 3 mid-hi each side.
That sounded pretty good and loud. I guess a stack would match a stack of Forty line Smile
A stack consisting of one sub and one mid-hi.
Edit: forgot all about HK Audio Projector system.
That would be a great piece of kit for you also. But that might be hard to find these days.
Not the biggest low-end performer system, but its a good sounding system.
Edited by FOO - 07 November 2023 at 5:10am
Andylaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andylaser Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2023 at 9:20pm
RCF have just released the new SUB8003 Mk3. A pair of these each side with an NX32A on top would be pretty good. If you can stretch budget to the 8004 subs, even better.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
