  New Posts New Posts RSS Feed - MT 122 As a 2-way passive MID TOP speaker
Captain Caveman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Caveman Quote  Post ReplyReply Direct Link To This Post Topic: MT 122 As a 2-way passive MID TOP speaker
    Posted: 15 March 2006 at 6:21am
How can i wire it so it is a two way speaker?
As in have the high pass xover in the box??
I'd like the box to end up 4 ohms so its cheaper in amps for it...
Is their anything wrong in doing it this way??
Go slow i dont know loads.
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 6:24am
You would have trouble finding a crossover that could handle the sort of power that you would need to run the MT122 properly. Also, the MT122 is a long throw design, and has a fairly narrow dispersion, so you would need a minimum of 2 cabinets per side for most events.
What type of event will the system be for? I would suggest the X15 might be a better option for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Caveman Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 6:29am
I generally use my system in fields or old barns.
I'm only creating a side rig-playing breakcore electro jungle dub psy trance.
So i'd be better off buying a small amp just too run my high frequency driver?
I will have 4 HD15's And 2 X1's for bass.
Ive got an Caudio MR3001 to run the tops.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Caveman Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 6:32am
I have been quoted 90 for an x12. But i need four of them really.
I was thking about to porn horn mids+ to high pass horns. But thats a wallet killer.
235 im hopefully going to pay for the mt122.No fittings paint.
soundgodwannabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundgodwannabe Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 8:00am
Speaking of power to feed these monsters. How much power is one talking about? I was wanting to build a pair of these and feed each cabinet with 500 watts. I think that would do, but since I am unsure, someone can tell me or straighten me out (get the pun on the straighten since it's all angles in the cabinets LOL). Correct me if I am wrong on this, but since this is a long throw cabinet, wouldn't it be correct to use this with horn type subwoofers and not an X1?
Edited by soundgodwannabe - 15 March 2006 at 8:02am
Make the soundman mad and I WILL press the suck button for your band.
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 8:21am
You can alter the dispersion of the cab by changing the comp driver horn to a wider one.  The 12" is too low in frequency to effectively be guided by the horn (see DOm's polar plots of the Porn Horn to see this in effect and a better explanation).
I use 1/2 a MT122 (1x12" and 1xhorn) per side and it covers ok
Power wise i put 550w per 12" driver and 700w per horn section (but these don't ever run much more than -10db signal light on the mid and -20db signal light on the horn)
Edited by norty303 - 15 March 2006 at 8:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Caveman Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 11:30am
700w into what would be an 80w@8ohm horn isnt that a bit excessive?
well ive giot am C Audio MR3001 its 625w@4ohm per channel.
The mid drivers themselves are 300w@8ohm .
Will run mids on one channel and horn on the other. That'll be ok wont it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 4:22pm
Actually my tops are beyma 550 comp drivers with 2x fane slot tweeters, totalling about 250-300w at 8R.
Like i said, you don't run them hard but a nice big amp does sound good.
The C-audio should do the job but i use PLX3402's so it's that or buy another smaller amp (and why would i want to do that?!)
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 10:39pm
Yes if you don't care about mono.
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundgodwannabe Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2006 at 8:13am
Norty~
So this is a bi-amp'd cabinet? Controlling it is an ... ultradrive or a external crossover? So, this cabinet couldn't be made as a two way system to put with a subwoofer (to make it a 3 way system). Using 500 watts for the MT122?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Caveman Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2006 at 12:02pm
i have found some one recently who dod put a selenium passive crosover over in the box. But he said someything about the horn having to be a higher impendance thn the mid or you will loose power?
dunno what he meant.
No mono is fine. I only have one stack systems not split.
You dont do that kinda thing where im from
minaximal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote minaximal Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2006 at 7:17pm
i'll make sure i dont go to where your from then..
how in this day and age with all the technology we have around us,
can anyone get away with a completely mono rig!?
Subs + Barges = :)
www.metaacoustics.com
