  New Posts New Posts RSS Feed - MT 122 Cut List
MT 122 Cut List
eaopmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eaopmedia Quote  Post ReplyReply Direct Link To This Post Topic: MT 122 Cut List
    Posted: 18 October 2014 at 3:10pm
Hi,
Looking to build an MT122 but noticed that the designs don't include a cut list. Is there one available? Also is there a 2x15 version
DanielIt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielIt Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2014 at 5:00pm
I never seen an cutlist for MT122,but there is an MT121 version drawn in sketchup from where you can make an cutlist,however is the 15mm ply version.I have 2 MT121 and are bloody heavy,MT122 must be horrible,imagine an 15" version.
Measure twice...cut once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eaopmedia Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2014 at 9:40pm
It's for an install so doesn't matter much about weight. Didn't really want to be learning a program to get my answer tbh so if anyone has made a cut list for this I'd much appreciate it :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote eaopmedia Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2014 at 9:47pm
Does the 15mm hold ok?
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2014 at 9:42pm
15mm is fine, its not the weight that would make a 15" version useless mostly its teh fact that it wont drop noticably lower and will not play as well up heigher so would become purely a low midrange horn that doesnt play very low if you need more output/extension a different design is best for you
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eaopmedia Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 2:25pm
Hi Mark,
Was aiming for 18mm anyway, but if the 15 mm was going to do the full range then that'd be cheaper, obviously not lol. Still after a cutting list. Is the designer on here at all?
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 3:19pm
i'm not sure what you're looking for exactly? nearly all the pieces you'll have to cut are irregular shapes. there's a lot of time involved in building these.. it won't take you much longer to sit down with the plan yourself and work out all the cuts you have to make. worth doing anyway for a full understanding of what you're building.
you're new on the site so we don't know your level of experience either... have you built many boxes before? the mt122 are not an easy build. but totally doable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eaopmedia Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 4:30pm
My intention was to get all the pieces cut by my local timber merchant and then assemble the pieces. I've only built cabs for guitar and bass, but have a couple of buddies that can help me put this together if need be. The cutting list would be handy so I can send it to my timber merchant, and if so many of the users on here have made these then I would have thought you guys would have a cutting list if you think that it helps to understand the build. I already have a grasp of the drawings but would like to have the cutting list, which you'd think would be part of the speaker design schematics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 5:24pm
i suppose they're just difficult to write out as a list.
i've always cut my own wood so always thought of it as part of the process.
look for the simplified MT121 plan, it's probably better documented. and then you can work out how to make a double of it.
the mt boxes are tricky builds though. well the trickiest bit is doing the cuts.. i don't even know how i'd write out a list of parts in a way others would understand. i did draw the box out myself in CAD before i started cutting, and just did it piece by piece.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eaopmedia Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 7:07pm
Probably best to take the MT121 plan, break it down to get the size of the 12" driver chambers, double that and then add the HF horn to the sizing and that'd probably get you the same result as the MT122?
Cserenkov View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cserenkov Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2021 at 6:34pm
It is an old topic that has been abandoned for many years, but maybe there is another specialist here who can help me?
I would like to ask for your kind help. And sorry for the bad English - I don't have English as my mother tongue, I'm Hungarian and have Russian ancestors! :)
I would build a pair of MT122 for my own home disco. I am not a carpenter, but an electrical engineer and, moreover, a very impatient person. I understand the transistor and everything else that is electric. But I don't understand carpentry!
I see a lot of successful MT122 rebuilds on Youtube and elsewhere. I want to ask for a cutting list because I don’t have the time and patience to measure it. My timber dealer cuts it to the exact size, and assembling it is no longer a problem for me!
Thanks for the help, there will definitely be someone here who has the full MT122 cutting list!
Best regards: Cherenkow
