  New Posts New Posts RSS Feed - MT 122 horn in glasfiber?
Dixi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dixi Quote  Post ReplyReply Direct Link To This Post Topic: MT 122 horn in glasfiber?
    Posted: 29 December 2005 at 6:03am
The horn part in the MT 122 is tricky to do with all angles. I have plans to build 4 single boxes like DOM did. The Porn Horn is done in glasfiber. Why not make the horn part in the MT 122 the same way? Is it done before? Comments?!
"But where is the speaker? thats just a box with a hole in it!"
Dixi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dixi Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2006 at 10:58am
I take your silence as a fact no one have done this, well someone has to be a first! To bad its to cold to do the fiberglas work right now need like 16-20 degrees and now its -3 here. And Ive got now option of working inside with this, could work with a good construction fan but the house would be unliveable.
Just writing again to see if any of you get some comments on this project?! Does it seem like a completly wacked idé?
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2006 at 8:49pm
plastic?
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2006 at 4:02am
I'm planning to use glass fibre to build some horns with phase plugs for 8" drivers.  My problem at the moment is what to use to make the mould.  That's going to take far longer than just fabricating the horns.
If you can make an MT122 from wood then take a plaster of paris mould of it, you could smooth it over, take out any sharp edges then use that to build the horns on.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2006 at 8:43am
you make the master from melomine board or moisture resistant (green) mdf.
and use any car body filler to give you the curves if needed
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2006 at 3:47pm
i think the mt122 is compromised in favour of being practicable to fabricate
from wood. the porn takes the next step in flare and round/square
transition etc because it is made from fibreglass. emulating the 122 flare in
fibreglass or plastic would be a step backwards in my opinion.
james.
mardy hippy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2006 at 4:11pm
James is right, if you're going to go to the hassle of making a mould and using fibreglass, you might as well having a go at something a little more exciting!
If you haven't already, check out Centauri's DIY pages and especially the phase plug stuff.  Adding a simple phase plug might extend the top end to a useful amount, not essential with a good 2" above though.  The things I've been playing around with on paper involve elipsoidal horns with simple cone shaped phase plugs.  Use Hornresp to find out what throat, mouth and horn lengths would work well for your driver (what are you planning to use?)
I'd be interested to work with you on this further if you're interested.
Dixi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dixi Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2006 at 5:27pm
Was planning to use P. Audio SN 12B Neo.
Yeah i had a look at Centauri's page but coulnt seem to find any plans maybe you need to email the guy?
mt122 with the SN 12B Neo done in singel boxes and in glass fibre aswel will make them very easy to deal with when they are done :)..
pretty much on the edge of starting the negative mould (?) for the horns.
james you dont think its worh it?
/k
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2006 at 7:38pm
If you can have some flat parts you can always place an aluminium skin on both sides of the end product for much improved stiffness without adding much weight. Also expanded structural foam is your friend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2006 at 7:09pm
the goal of a nice lightweight variant is truly worthy, as ceharden suggested
it just seems a shame to be using a more developed technology that is
capable of producing any desired shape and not trying to develop the idea a
bit.
as i understand it one of the biggest issues with such a horn is getting the
round to square transition to work nicely, i'm sure by shaping down a block
of foam or similar you could make a better job of that part than the mt122.
james.
mardy hippy.
