  New Posts New Posts RSS Feed - MT/limmer
MT/limmer
Father-Francis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Topic: MT/limmer
    Posted: 26 February 2010 at 8:45pm
just what the heading says , taking MT to a different level.
the Mt12 with the  Limmer 042, loaded Ciare 6.38MR3, BC.Speakers DE25, the snow is melting .
time for work.
I welcome all of your comments and suggestions. What kind of comment would you like to send? Complaint ..................
 Enter your comments in the space provided below
colinmono View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colinmono Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2010 at 9:50am
Should be a good combo, Dom had some cabs with Porn Mk1 12" horns and Limmer 042 which he spoke highly of.
nomis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nomis Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2010 at 10:48am
i ve been using the limmer042/12 in horn underneath.good combo.takes a while getting the delays right,as crossed at 500,if you get it wrong,it can make vocals less pure(split across two drivers).also,the limmer has a very clean sound,which can take a while getting used to if you are used to 'crunchy' snares.
all that glitters is not gold
dj-panoramix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2010 at 1:10pm
you use limmer 042 with limmer 312 ?
what the recommanded crossover point between the 6,5 and the de25 ?
Bjørn Dub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bjørn Dub Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2010 at 6:52pm
Bump..
Was just about to aks all these questions to, I guess our minds think alike here Francis..
So here goes, whats the recomended crossover ?
Next investment will be 4 - 6 of those lovely packs.. cant wait..
1850 FRB C. (;
Post Options Post Options   Thanks (0) Thanks(0)   Quote nomis Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2010 at 7:34pm
hi,i built the crossover recommended on the speakerstore site.it works very well.before that,i used an ultradrive,and ended up crossing around 2-3k,but found a 5way active rig too complicated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2010 at 7:35pm
Installation dimensions 358x358mm
Phase plug in the 6''Horn
Suitable for midrange driver 6''
e.g. The Ciare 6.38MR3.
Separation at about 500Hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2010 at 7:57pm
of course it is specially when you use 1way that you was not supposed too...i don't understand why you choose the limmer 312 indeed of limmer 085.
312 according to the limmer website go only from 300hz and up, the 085 go enough down to meet a sub so you would have only 4way with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nomis Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2010 at 8:20pm
no.i meant hogs,martin115,12in horn(own design)then limmer042,which if run active makes a 5way system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2010 at 8:39pm
We are also running a 5way system sounds wicked
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2010 at 9:28pm
ah ok... Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2010 at 3:05pm
How does your limmer keepup with the 12" , cause we was thinking of 2x12" an the limmer on top of that. you get me? 2mt section per Limmer 042 , we are just waiting for the limmers Party
This page was generated in 0.219 seconds.
