  New Posts New Posts RSS Feed - MT/limmer
MT/limmer
huhts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote huhts Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:51pm
Thank you! That's what I was thinking also. The limmer p2 and p3 designs (speakerstore.nl) just have some bigger enclosures behind ciare that confused me a bit.
Nachural View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nachural Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2011 at 5:20pm
I’ve been playing around with the limmer combination for a while now. Small rear chamber volume is definitely the way to go. Sounds sweet in short throw applications.
it's all just cardboard and magnets really
Pirlo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pirlo Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2011 at 10:53pm
update?!?
Who the fu&k is Mr. Phanton, and why he has so much power!?
hulkeh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hulkeh Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2013 at 4:51pm
Originally posted by Father-Francis Father-Francis wrote:
the cabs are Pd123 in the 12" , Limmer 042, Ciare 6.38MR3, BC.Speakers DE25, I´l say each cab´s about 1150£ when done we´l be making wheel-boards F1 style to move them around .
What crossover points did you use?Clap
Father-Francis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 5:41pm
12" run from 140-around 950-1000 the Ciare 6.38MR3 runs from 900-3k then BC. DE25 does, the rest you can always fine tune from there if you don´t like the sound .
Francis
Post Options Post Options   Thanks (0) Thanks(0)   Quote hulkeh Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 6:56pm
Nice, thanks :)
Been thinking about the mt limmer combo but just weighing up costings and things :s
What's your opinion on the cab? Would you recommend it?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 7:09pm
it´s  a good cab just don´t put three per side in a thin room cause the top spreads quite much. two per side max.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 8:50am
Five years later speakers still going strong, now They’ve come up with something new
and this one too I want to play with these this winter
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2018 at 6:06pm
the limmer 308 aint exactly new at all afaik.. unfortunately they are too shallow/small to meet "usual" kicks properly imo - i would go with Bens/Bees take on "porn horns"/"SP12s" if i would consider such a 4way setup..
This page was generated in 3.641 seconds.
