MT102 Build Pic's |
chonkie
Registered User Joined: 09 April 2016 Location: Irieland Status: Offline Points: 33 |
Posted: 17 October 2017 at 10:40am |
Hey so i recently built two MT102's from the designs on the front page.
Noticed there was very little pictures info about them so thought i'd put up some! Really great sounding box and very easy build. I think I spent 1 day cutting and 1 day putting it together! Baffle hole cut and two braces attached Flare braces attached on 1 side Driver baffle fitted (tip leave screws in when gluing to prevent t-nut getting glue in them!) Flexi Ply glued & screwed Sides & Back Fitted FRONT VIEW BACK VIEW
If you have any questions regarding the build please let me know! Edited by chonkie - 17 October 2017 at 10:41am |
njw
Are you sure you weren't taking pictures when I built my old pair as I assembled mine in exactly the same way?! What are you loading them with? I only had cheap Fane Sovereigns in mine yet they still surprised me everytime I used them. They could be brutally loud and crystal clear at the same time, and the throw was daft. I don't know why they aren't more popular as they are very good cabs.
T-Bone
Registered User Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 292 |
I heard these on top of mid bass and 186's they sound pretty good for an old design crisp and loud on youtube. It would sound a lot better if it was infant of me. I have 4 Faital Pro 10PR300 neo's, was thinking of building these but my crowd size most of the time 250-300 I don't know if these will be overkill. I have reflex stuff now so I am inclined into building a pair too.
BASS, how low can you go!
IainB
Registered User Joined: 25 November 2016 Location: Rushden Status: Offline Points: 422 |
Now I can make sense of the plans on the front page, just getting ready to build a set (once Ive finished parts collecting)
subu
New Member Joined: 18 February 2024 Location: india Status: Offline Points: 2 |
greetings planning on doing two of tghese boxes ,if somebody could help me with the size of the flares on mt 102 ?
subu
hey can you help me with the size of the flares ?
bob4
Print or draw the plan, take a small lenght of sewing thread, lay it on top if the flare contour. From that you can calculate the lenght of the flare boards. Drawing the plan in 1:10 scale is the easiest. If you just print it, you will have to calculate the scaling factor based on the dimensions of the print.
