  New Posts New Posts RSS Feed - MT102 Construction
MT102 Construction
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Topic: MT102 Construction
    Posted: 27 October 2004 at 5:46pm
Does anyone know how the slopnig sides of the MT102 are supposed to work?  Does one cut down one edge of the timber to a paper-thin edge, or does it start 60mm at the driver end, and finish at 18mm (the timber thickness) at the cabinet base, and the same by the middle section?
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2004 at 6:52pm
I'd cut it with a 9.5 degree mitre on the end that meets the baffle and a 80.5 degree mitre on the end at the front of the cab.  Same angle, you just have to hold the piece at 90 degrees to the saw when you cut the 80.5 degree angle...
