MT102 Help |
mullet
Registered User Joined: 29 September 2010 Status: Offline Points: 60 |
Posted: 17 October 2010 at 1:38pm |
I was thinking of building a pair of MT102 cabs to go with my system, but due to low budget i am unable to afford the compression drivers and horn, so was wondering if there are any suitable budget alternatives.
My system is not a business and will not be used for hard road use so it sounds bad but the components don't need to be of a professional quality
i will be using Eminence Kappa Pro10 drivers as the bass, any suggestions on cheap compression drivers and horn to go with this? and also a suitable crossover, that will cross around 180k and 1.5k thanks in advance |
mullet
The suggested compression and horn are: compression driver - Beyma CP 800Ti horn - Beyma TD460
