  New Posts New Posts RSS Feed - MT121 build
MT121 build
streetsounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2010 at 6:00am
Very nice work indeed. How does it sounds with with those PAudios.
Bass matters...
JMPROAUDIO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMPROAUDIO Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 1:51am
There is so much on this forum, I thought I had searched through everything, but there must be some other stuff dug away somewhere else lol.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 12:22pm
the standard search only searches last 6 months. change it to "any date" and try and search with some good specific terms and hope it works.... it often doesn't work for me and frustrates me greatly....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 2:26pm
So how does the SB18 perform? Does it go low enough?
lukam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukam Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 7:24pm
Hi,
as cravings said there are plans for the double 12. We build this mt121 from the double plan and there was alot of guesing what angle is where. When the box was almost finished I wrote down all the angles and mesaures from the finished box but I lost the paper where I wrote themCensoredOuch.
@Marjan
We build just one SB18 for testing as we had some mdf left. We tested it with an RCF L18S800 and the output was at first quite good for that small box. There was a lot around the 60 mark but boomy above 100. The low end was there but as we tested it more the driver got over x-max soon. Not the best driver either. We had no measuring equipment back then just listened to it. Now the box is lying somewhere but if I get a better driver to test it I will measure and post it here.
Edited by lukam - 11 September 2010 at 7:25pm
