  New Posts New Posts RSS Feed - MT121 Drivers...
MT121 Drivers...
 Post Reply Post Reply Page  123 10>
Rawcardo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawcardo Quote  Post ReplyReply Direct Link To This Post Topic: MT121 Drivers...
    Posted: 23 March 2012 at 2:48am
MT121
B&C 12PE32 or B&C 12ndl76?
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2012 at 9:39am
as i said last night ive used both, the ndl wins for me, very warm sound and it makes the box alot lighter.......
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2012 at 9:40am
ill dig a plott out of both drivers in the mt
PISSHEAD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PISSHEAD Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2012 at 10:08am
12pe32-freq- 50-4000k--250w--- 7.6kg--£131 each (Blue Aran price)
12ndl76-freq-50-2000k--400w---3.9kg---£239 each
Both are good drivers and the cost for me would determine which one I'll pick. Pe32 goes up higher.
The 'drunken master' strikes again.
vibez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vibez Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2012 at 10:13am
surely you would cross to c/d's well under 4k anyway??? I cross mine at 1.3k.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawcardo Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2012 at 2:46pm
Ya I think the 12ndl76 will do the trick... Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PISSHEAD Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2012 at 8:36am
Vibes, You can play the pe32 upto 4k and still cross your cd at 1.3k using a BSS minidrive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PISSHEAD Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2012 at 8:43am
Bee, I know you said you like the 12ndl76 better, at which crossover type/slope did you use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote vibez Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2012 at 9:11am
oh i agree it can be played up to 4k, as you can with many drivers including the bms 12's that i use. but my question related more to the fact of how efficient will any 12" driver be at 4k??? More efficient than a compression driver??? I dont think so.
I cross my cd at 1.3k but play my 12's upto 2.5ish with a little bit of eq on the 12's around the crossover point because they start to roll off around 2k even though they can apparently play upto 4k according to the specs. they will of course hit 4k but just not better than a cd so it just seems rather pointless. please don't consider my post as critisism as i'm no proffesional, it's just my opinion after running mt's for a couple of years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vibez Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2012 at 9:14am
@pisshead where are you based in the midlands?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2012 at 11:50am
Vibez, you overlap the 12 and the HF? Which BMS you use?
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2012 at 12:15pm
how can they overlap if it doesn't meet the comp in the first place? Wacko
view this graph for a double
http://forum.speakerplans.com/topic15865&KW=MT122_post153570.html#153570
Edited by mykey- - 24 March 2012 at 12:17pm
This page was generated in 0.657 seconds.
