  New Posts New Posts RSS Feed - MT121 - Fibre Glass Horn Version
 Post Reply Post Reply Page  <12345>
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2012 at 9:06pm
"Would shorter horn extend high end response?"
longer horn would extend the low end, by making the horn shorter in length it would just bring the low end back up. To bring the high end response up would be to use a phase bung
BC pe32 is what I have used, most mid band drivers will work in this horn Lev
what drivers did you have in mind? and please don't say PD121Dead
PD123, Celestin Tn series
Originally posted by infrasound infrasound wrote:
Any reason you're using an adult uploading site mykey? Wink
Ps. Ooh..
these looked mint when i saw em Smile
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2012 at 10:08pm
Originally posted by Dan321 Dan321 wrote:
@ father francis re: The all round handles,was it this thread?
http://forum.speakerplans.com/new-build-job-number-two-2-x-15-1-full-range_topic50309_page3.html
cheers mate
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2012 at 10:13pm
Guy's this thread is not an add for Mykey stuff, please take it somewhere else.
Or it'll be another thread for the chop.
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 4:29am
Will fg horn be as optimum as wooden flare without bowl?
People buy their cabs with their own cash, so it's their choice which driver they use.
Have heard MTs with 2" + PD123ER, PD121, Eminence Kappa Pro, Fane 12MB, engineer knew his way around LMS & parametric, so it sounded fine.
Appreciated. But have you measured them? just listening - yes they will sound fine. But lot's of peeps can't here gaps in the bandwidth. I noticed that at the sound checks
Midrange horns are not like Bass bins. Driver plus horn must match.
whats wrong with the PE32? great driver, put's the PD121 to shame in a horn
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 9:14am
+1 on the pe32..... my fav is the b&c 12ndl76 ......... for me this just out does the pe32..... but both are great in horn loaded tops.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 10:56am
that's whats in the cabs above (answer for tweet)
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 11:05am
Due to MT121 Horn design, unless you cross 2" in at 1.5khz,  you will get gap in bandwidth.
The PE32 has a good reputation, and sounds nice, but is not in everyone's budget.
Most SP people know at least 3x guys who can supply cheap PD, Fane, Celestion, Eminence.
So it's cab buyer's choice.
So if FG MT121 horn can't work with range of good drivers, and not much improvement on performance, and not cost efficient, then no point really.
Edited by levyte357 - 24 February 2012 at 11:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 11:20am
Then make do with a Elvins style mid horn, 2 bends of ply. Will take every driverWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 12:25pm
Is that a phase bunged 6" & 1" ?
May look good, and sound great at lowish SPL, but wiil they keep up with the 12" at high SPL at distance/outside ? We already know what happens to Xtro top end, when the 15s get going.
In terms of SPL outside, can 6"+1"  match what's possible from high powered JBL/B&C 2" ?
Edited by levyte357 - 24 February 2012 at 12:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 2:33pm
Lev here is a driver you should try , but then again it´s a big boy ting , for people with deep pockets or heavy wallets ,
http://oem.ciare.com/en/296/344/prodotti.php
Big smile
Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 2:54pm
Big smile
Big smile
Not for me.. LOL
Plenty of reasonable priced options for MT121 that are firing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2012 at 3:05pm
Lowish BL on that Ciare thing. Get BMS 12N810 from Tony :-)
