  New Posts New Posts RSS Feed - mt121 new build
mt121 new build
 Post Reply Post Reply Page  <1234 6>
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2008 at 10:36pm
realy? limmer horn springs to mind.
ciare 6.83mr iirc
or just sod it and go with the original plan!
insert silly sentence here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2008 at 10:38pm
www.speakerstore.nl
have a looky on there for the limmer 042 horn, alough its not cheap ,....or lyndonA on this forum has a 2x6" [i think] and 1" mid top box he designed around a cheapo eminence driver which may work well for you?
Any of these options will be fine though to be honest!
djbenwells View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djbenwells Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2008 at 11:37pm
The limmer 042's are very nice indeed out of my price range at mo!. I think i will stick to the plans as they do sound soooooo good and loud.
boycey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2008 at 10:20am
i have a pair being fabricated as we speak!
i was thinking about putting a mt121 underneath but am worried about dispersion- limmer is 50, mt is 40, would be nice to get a 12, 6.5 and 1 all matched up with 50 dispersion- poor man's floodlight style.
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2008 at 1:30pm
limmer 042 is wider than that.... 75° i think. i've no personal experience of these... just read up a bit about them a while ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2008 at 3:23pm
so it is oooops.
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2008 at 2:26pm
Quote mt is 40
Which section are you referring to?
The 12" section doesn't offer very much control over the dispersion because of the small mouth (to quote Dom Wink) so i wouldn't be put off from using it for a wider dispersion type cab.
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2008 at 4:12pm
Originally posted by norty303 norty303 wrote:
Quote mt is 40
mouth or horn length?
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2008 at 3:59am
Well as i said, to quote Dom, who said horn mouth, (and i know very little about horn theory) but the horn length is only the same as a wavelength of ~730hz which is in the region of where you're crossing to the 2" so may be that also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2008 at 10:55am
thanks for that
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2008 at 7:35am
I did some polar plots of the 12" section a few years ago...
They're not directional at all at the frequency you'd cross over to a limmer...
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2008 at 8:28am
thanks very much for that! looks like summer could be busy
don't suppose the plots are still about?
