  New Posts New Posts RSS Feed - MT121 questions
MT121 questions
SonicXtasy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SonicXtasy Quote  Post ReplyReply Direct Link To This Post Topic: MT121 questions
    Posted: 08 August 2008 at 12:58am
Hey guys, finally revising my system and need some opinions. I will shortly have 2 X1's (adding 2 more later) and four 2 X 15" reflex kick bins. I have a set of P-Audio SN12B's and will be getting another set soon. I also have 4 Selenium D3300Ti DPD 2" exit comps with Community 60 X 40 horns (probably replace horns with smaller units). I assume my Selenium comps will work in the design. Will 2 pair keep up with the 4 X1's and 4 kicks? How low will they play and what is the recommended xover freq. Lastly, how well do they sound? will they take your head off at close range? I am also considering the the SMT212 (coaxial mounting the horn between the 12's) which is not actually horn loaded. How would the 2 compare in sound quality and output? The MT122 is just too big for what I want to lug aroung as tops. Any advice would be great.
The member formally known as vwbidder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SonicXtasy Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2008 at 1:03am
Forgot, the other reason I am considering only 1 12 per cab designs is because the current 2 amp choices I have for the mids are only 4 ohms stable, a Crown Powerbase 3 or a Samson S2000. I might be able to trade some stuff to a friend for his QSC PLX2402 which would run 2 ohm.......and match my 2 PLX3402's nicelyWink
