MT121 revisited, revised |
Post Reply | Page <1234> |
UpComingSound
Registered User Joined: 21 June 2006 Location: United States Status: Offline Points: 393 |
If any one can help me out, question I just purchase the B&C 12pe32 for mt 121 and am using the ashley protea 4.8sp for crossover what should i set the cross over settings at ? HPF freq and LPF freq right now I have the HPF at 150 and LPF at 2000 is that a good xover setting?
cravings
can't get my MT121 12" sections to go much higher than about 900hz...
pfly
Slight update: I made a version with a space for horn and compression driver, the cutout I drew is for 18Sound 1,4 to 2 inch XR series horns but there is enough space for example JBL 2380 series of horns.
https://dl.dropbox.com/u/9726318/mt121/mt121_twoway.skp |
soundchippy
Young Croc Joined: 09 September 2011 Location: Tavistock Status: Offline Points: 770 |
thanks plfy! i'm going to make it my summer project to finally build and test one of these.
scss
Registered User Joined: 07 February 2013 Location: UK Status: Offline Points: 35 |
Does Anyone Know If The Fane Sov Pro 12-500 Will Fit / Work Well In This Cab?
pfly
Update from other thread:
bozhidar
Registered User Joined: 31 March 2014 Status: Offline Points: 31 |
Hello! The driver I want to put inside the single MT121 (without the horn) is 155 in total depth. How can I modify the back chamber to fit it in? How much space do I need between the magnet and the backdoor? Right now there is 145 MM from the baffle to the backdoor.
Miles
Registered User Joined: 26 September 2013 Location: Germany Status: Offline Points: 76 |
4 mt121 bulit after the 15mm plan by forum member pfly - give thanks for providing the plan - first audio measurements and thing looking good! |
T-Bone
Registered User Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 292 |
The later 2 way version in 15 mm with CD top, isn't this MT121 40X25 degree dispersion? So I would need 4 per side for 160 degree splay? I am thinking JBL 2386 2" horn with a JBL 2450 CD?
Thanks for the input, 12PE32 is what I am going to use. |
BASS, how low can you go!
bob
New Member Joined: 30 July 2018 Status: Offline Points: 1 |
Hello,
can you please reupload the plan? Would be very helpful!
Archi
Registered User Joined: 24 February 2019 Location: Taiwan Status: Offline Points: 19 |
Hi all, I've been lurking here for a while and ready to build MT121 next week
Lots of pics of MT121 has been removed or gone also the zip file in previous discuss , I need more information(like flare angles) before I start it. Could anyone send me the file? I'll thank you thousand times! |
nejten
Registered User Joined: 04 November 2019 Location: Belguim Status: Offline Points: 75 |
Hi everyone, I can't open any of the links posted. Can somebody help me with this? Bless
From small acorns oak trees grow.
