MT121 |
Rockin
Young Croc Joined: 02 April 2007 Location: Rotherham Status: Offline Points: 737 |
Posted: 02 May 2007 at 12:31pm |
Right got the boxes built. Some pics to follow.
Im going to be using the P Audio SN12B, a JBL 2445J on a JBL 2380A flare, and a couple of Fane 5022 Slot tweeters. ive got the passive crossovers for the Fane slots, but need to find the best crossover frequency for the JBL 2445's Its going to be passive as i dont really want to spend on more amps. Its a compromise i know. I was thinking about 1.6k would be best. Have you guys any suggestions about this before i dive in? Also the 2445 is a 16ohm driver, most passive crossovers are 8ohm, will this affect things that much, and if i did use a 1.6k filter, what would the crossover frequency actually be considering that there will be a mismatch with ohmage Thanks in advance |
Rockin
Ya know ive been thinking about it all day. The cost of the passive crossovers for decent ones anyway, i could get an amp to power all the tops, (2445 and fane slots) as i have a Behringer CX3400 3-Way Stereo/4-Way Mono xover. im already using. Not sure on the quality or power of the amp i need but saw these on the net which are quite cheap. Would it be good enough?
http://www.catapult.co.uk/products/DJ%20Equipment/Mobile%20DJ/DA+800+Amplifier WARRIOR - DA 800 AMPLIFIERTECHNICAL SPECIFICATION- Power Output (4 Ohms) - 400 watt- Power Output (8 Ohms) - 300 watt - Frequency Response - 10Hz - 25Khz - Weight - 10.5 Kgs - High Quality Stereo Power Amplifier - Heavy Duty Casing - Volume Control Knob Indicators - Peak Level Indicators - Protect Mode Indicators - Active Fan Cooling System - Short Circuit and Thermal Protection - Efficient Soft Start - Speakon, Jack and Binding Post Outputs - Jack and Phono Input |
soundsystemdan
Young Croc Joined: 04 April 2005 Location: Leeds UK Status: Offline Points: 716 |
Re crossovers, you might find your answer on this thread.
And that amp, you answer's in the question...
Rockin
Good info in that thread
Any suggestions of a decent amp, lightweight if poss and 2u max? |
Strange Daze
Old Croc Joined: 14 July 2006 Location: United Kingdom Status: Offline Points: 2861 |
serious mate.....
Just had the Warrior 1200 (that i have on extended loan from Inverted System), go bust :(
......for the same price point, i much prefered my Carlsbro Powerline2000. only 1000watt (4ohm) stereo, as opposed to the Warriors 1200w. The Carlsbro was 25kg(ish), but sounded stunning on top end....(not a massive amount of ooomph for bass, but it was okay when needs be.....)
£200 to aint bad......
Rockin
Had a look at the carsbro amps the other day too
Just nipped in my local music shop today. Saw a Peavey DPC 750 1U amp, which runs @ 375w per channel @ 4ohms. Anybody have any experience with these for top end? |
