  New Posts New Posts RSS Feed - MT122 DRIVERS
MT122 DRIVERS
303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 303 Quote  Post ReplyReply Direct Link To This Post Topic: MT122 DRIVERS
    Posted: 29 June 2019 at 4:03pm
HI
just bought some 122 home builds and looking at options with what to load them with
currently running
4 staiper micro hogs with fane 600lf
2 x 215 courts wbins
running tamp 2 x 2400
mid tops amp thonman 1400 so with 4 x12 drivers and already have comps from my current tops only 1inch but will try them first
recommendations for the drivers
music style techno
Amplifier with Switched-Mode Power Supply
  • 2x 670 W/ 4 Ohm
  • 2x 450 W/ 8 Ohm
  • 2x 800 W/ 2 Ohm
  • 1x 1380 W bridge at 8 Ohm
  • 1x 1600 W bridge at 4 Ohm
  • XLR input and output
  • Speaker Twist output
  • Protected circuit design: Audio limiter, temperature und short circuit
  • Dimensions: 484 x 350 x 97 mm
  • 19"/ 2 RU
  • Weight: 10.4 kg
Further Information
Power (4 Ohms) per Channel670 W
Channels2
Rack Units2 U
Amp ClassClass H
2 Ohm stableYes
DSP/CrossoverNo
Convection coolingNo
boots-hifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2019 at 8:09pm
If you’re playing techno why on earth would you buy scoops? I’d sell the W bins and scoops, but some FLH like ES18s/USBs/Invaders even some old turbo 218s. I had Mt121s loaded with BMS 12n610s and 4550s. PD123er work well, loads of options from different companies. Do a bit of research before you waste any more cash.
303 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 303 Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2019 at 8:22am
look i did not ask for you to  tell me whats wrong in your opinion with what equipment i have, but thanks
question asked was help with driver choice for what i have , many thanks
i had a budget like many and started with what i can afford and for what i paid i will never have wasted my cash thanks as selling all separately will net me easily double  what i paid for it as a whole
and was doing research , that has has bought me for advice here
