MT122 Plot |
Post Reply | Page 12> |
Rog
New Member Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
Posted: 18 February 2009 at 5:55am |
Hi,
I get asked how low will the MT122 play all the time, so thought I would link to this post that has a plot I did of an MT122 a long time ago.
Rockin
Young Croc Joined: 02 April 2007 Location: Rotherham Status: Offline Points: 737 |
Wow they go down to 125Hz well. Very nice
Timebomb
Old Croc Joined: 11 October 2004 Location: Lancaster Status: Offline Points: 2717 |
Nice one Rog, theres another plot you did of a single 12" MT horn here:
http://www.speakerplans.com/forum/forum_posts.asp?TID=11586&KW=boke&PID=106434#106434 Can you remember if the plot you did of the MT122 was in half space or free space? Just finnished the last of my punishers today and im hoping i can use them with the single mt112s i have, not tryed it yet, ive been running the punishers up to 120Hz this week with some reflex tops, sounds quite good but some very tight kicks can make the punishers sound a little rough so will try a 100Hz cross to the MTs tomorrow, the MTs kick hard as i remember, hoping 3 MT 12"s to 6 punishers will work nicely as i can fit that lot in 1 van load. |
jonny4288
Registered User Joined: 06 August 2008 Location: N.Wales (WXM) Status: Offline Points: 586 |
that plot is useful, thats exactly how my mt122 are constructed, with the two 12" coupled
nice one! |
heinrich
Registered User Joined: 21 February 2007 Location: Calindagan Status: Offline Points: 280 |
so at what frequency will it start to comb filter? for a wild guess is it 900hz and above? |
.....power is nothing without control....
norty303
It shouldn't comb filter (to the detriment of any sound) if its crossed over correctly as the 12"s should not be playing anything by the time they uncouple.
Anything will also be in the vertical plane anyway so much less of an issue
Edited by norty303 - 23 February 2009 at 6:31pm |
heinrich
as we could see on this pic, lobing in the vertical plane at 900hz would be much improve...? |
norty303
My pic was based on separation based on the original plans. As you can see its not really an issue in the vertical plane. Obviously it will be better with the horns right next to each other, but its not exactly bad to begin with!
heinrich
I was also hoping that Rog could write his views why the two 12" were arrange in that way,
since I coudn't find posts concerning this.... |
norty303
I'm guessing its to do with acoustic centres, in the same way that line array cabs have the HF at the centre followed by mid and LF towards the outside. Ultimately its about practicality, ensuring that the various sections are close enough within their respective passbands to couple effectively.
heinrich
mmmmm......ok
I was actually thinking of doing it the same way it was measured with the 12's close together... |
psytron
Registered User Joined: 13 July 2007 Location: Australia Status: Offline Points: 172 |
here is my plot of a MT122 using std design and SN12b
