  New Posts New Posts RSS Feed - mt122 sketchup (not a plan request)
yoshi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yoshi Quote  Post ReplyReply Direct Link To This Post Topic: mt122 sketchup (not a plan request)
    Posted: 06 October 2013 at 9:57pm
I am currently drawing MT122s in sketchup from the hornplans.fr plans
http://hornplans.free.fr/mt122.html
Obviously nothing fits the way i want it to when trying to do this, these are my first attempts.  My problem is I have drawn the flare from the flare lengths provided, and the 12 degree angle as marked is now 11.4degrees.  I originally started from the outside of the cab and found similar problems, so decided it would be better to draw the plans starting with the flare and modifying the exterior of the cab to fit.
I have a few questions:
Should I draw the plan based around 12degree and 24degree angles on the flare and alter the lengths or should I draw the plan based on the lengths provided and use these slightly off angles?
How critical is the volume inside a flare? If none of the angles/lengths quite match up surely I will never find the ideal volume?
Am I approaching this the right way?  I notice everyones mt122 builds are slightly different, is it a case of just going with what i think would be the best compromise?
Edited by yoshi - 06 October 2013 at 10:01pm
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2013 at 11:44pm
12 and 24 degree is correct. the plan is correct, just miss leading.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote yoshi Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2013 at 2:11am
I shall try again. I guess i'll try starting from the angles this time round. ty
