  New Posts New Posts RSS Feed - MT-130 doubt
MT-130 doubt
superspunk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote superspunk Quote  Post ReplyReply Direct Link To This Post Topic: MT-130 doubt
    Posted: 17 December 2012 at 5:04pm
Anybody knows the dimension of D??
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 5:11pm
71-(4x1,8)
Post Options Post Options   Thanks (0) Thanks(0)   Quote superspunk Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 5:18pm
I dont understand your answer... (4x1,8??)
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 5:30pm
Edited by JR.junior - 17 December 2012 at 5:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 5:35pm
1.) 1,8cm thickness of panel. (chipboard, mdf): 71,7-7,2=64,5cm
2.) 1,9cm thickness of panel (ply): 71,7-7,6=64,1cm
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 5:45pm
should the baffle not be 30mm ofset from being flush with the front of the cab?
Post Options Post Options   Thanks (0) Thanks(0)   Quote superspunk Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 6:19pm
Another way for the question...
D1 and D2 ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 6:35pm
whatever!
Post Options Post Options   Thanks (0) Thanks(0)   Quote superspunk Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 7:05pm
Ok, so you suppose that x = 2 x 1,8..    Why?
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 7:49pm
hey
The short answer is that it doesn't matter.
Compression drivers, being sealed drivers by default, dont need to worry about the size of the chamber they are in, they dont need any particuluar volume to work. So you can set the baffle that the horn screws into wherever you want really.
As people have said you'll probably want it back 30 or 40mm from the front so that you can get a grill on if you plan to use one, but other than that you can decide yourself.
k
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 7:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 7:54pm
looks good to me.... being 2x18mm should make leveling out the baffle much easier
This page was generated in 0.076 seconds.
