  New Posts New Posts RSS Feed - Mth 46vs question
Mth 46vs question
Joey carlo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joey carlo Quote  Post ReplyReply Direct Link To This Post Topic: Mth 46vs question
    Posted: 23 May 2023 at 10:11am
Hey , not posted her for a while but got the bug again and actually making full use of my sound system๐Ÿ˜…
So i had 18" scoops but wanted to try something different, i like scoop but they always seem to be missing something when playing house music (the normal dip they have) really shows on house music and i wanted something smaller and flatter in the 50-120hz range.
So i see these and thought , easy build, measurements look good and i already have the 18g401 to load in them so i built them (took only a couple of hrs each to knock together)
Really like the sound they produce , compete with scoops in regards to "weight" and also have that higher thump i was after. Really happy.
So my question is , i need to place handle and optimum position is in throat are infront of driver , now will that affect the tuning of cabs? Maybe someone can help me with that? Would be ๐Ÿ‘
Thanks
Edited by Joey carlo - 23 May 2023 at 10:12am
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2023 at 6:02pm
If you place it in the middle of the cone it will be fine. If you make a butterfly routing & backing box, it might even act as a crude cone correction (google it)
Edited by bob4 - 24 May 2023 at 8:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joey carlo Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2023 at 7:30pm
Interesting , ill look into that!  thanks ๐Ÿ‘
Anyone else built these cabs?  would be good to get opinions! I like them alot.
It isnt a true th from what i can see, almost th / paraflex hybrid maybe? But works great , spl lvl are real good and pretty flat ๐Ÿ‘
