  New Posts New Posts RSS Feed - MTL46 and B&C 18TBX100
Foca_Dacian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foca_Dacian Quote  Post ReplyReply Direct Link To This Post Topic: MTL46 and B&C 18TBX100
    Posted: 02 May 2018 at 11:45am
Can any one tell me if the B&C 18 TBX100-(4 ohm version) will work in the MTL46 by Marc O.?
Here are the Thiele/Small parameters side by side with the RCF LF18G401 (the driver that the project was build for)
 18TBX100                                          LF18G401
Fs 30 Hz                                            Fs 33 Hz
Re 3.7 Ohms                                      Re 4,8 ohms
Qes 0,33                                            Qes 0,3
Qms 7,0                                             Qms 7,6
Qts 0,31                                             Qts 0,29
Vas 256 dm3                                       Vas 268 dm3
SD 1210 cm2                                       SD 1220 cm2
no 1,96%                                            no 3,09%
Xmax 9 mm                                        Xmax 8,5 mm
Mms 230 g                                         Mms 182 g
BxL 22                                                BxL 24,6
Le 1,73 mH                                         Le 2,4 mH
EBP 90 Hz                                           EBP 110 Hz
link to the plan:
Edited by Foca_Dacian - 02 May 2018 at 11:48am
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 12:31pm
Marc WILL answer you on the English forum of his site
This page was generated in 0.102 seconds.
