Multiple amps in same freq band |
Page <1 345 |
bass traffic ![]() Registered User ![]() Joined: 11 May 2010 Status: Offline Points: 1283 |
Yeah I've been wondering about using different amps for the same signal, think perhaps same make and model is gonna be best if I daisy chain them. Looks like I'm gonna have to get in more debt to the bank and buy even more amps!
malc01m ![]() Registered User ![]() Joined: 23 August 2011 Location: France Status: Offline Points: 42 |
I'm amazed no one has thought to mention XLR line splitters as the solution. I use a relatively cheap linesplitter from Stageline , LSP-102 .... These don't have major electronics involved in their circuitry so this cheapo product is in fact robust and does the job of providing a proper signal to the amps with no confusion...
http://www.stagebeat.co.uk/P/111153/Stage+Line+Line+Splitter+LSP-102+251680 A bit of shopping around and they can be acquired much cheaper than this... Edited by malc01m - 14 December 2011 at 11:32am |
HighGradeBlazer ![]() Registered User ![]() Joined: 12 December 2011 Status: Offline Points: 10 |
This helped me a lot cheers!
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 7070 |
I hate to start confusing anyone, but what about amps like Crest that use pin 3 as the hot. That´s going to be fun for anyone doing direct amp to amp links. Best thing is to keep to one brand of amp per rig unless you really know what you´re doing!
![]() EDIT: maybe that should be old Crests - like when they were Crests and not Peaveys! ![]() Edited by Earplug - 04 January 2012 at 4:38pm |
grazzeee ![]() Registered User ![]() ![]() Joined: 06 July 2011 Location: Portsmouth Status: Offline Points: 440 |
http://www.amazon.co.uk/dp/B0002E57D4/ref=asc_df_B0002E57D48462657?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B0002E57D4
simple and effective... turn your X2 outputs from your cross over into X6... |
colinmono ![]() Young Croc ![]() Joined: 10 October 2007 Location: Midlands UK Status: Offline Points: 1111 |
Of course that will work, but daisy chaining is a much cheaper solution (or Y splits if you have no link out on your amp inputs). |
from experiance splitting the cable reduces the signal volume and quality...
also with the board you can control the volume of each output.. so if your amps are all differnt you can run them all on full then control the volume into each amp indavidually. |
Interesting. If I understand the theory correctly, with modern(sih) gear with low output impedance and high input impedance, the tiny drop in level from splitting is not significant (i.e. barely measurable and almost certainly not audible)... and this is borne out by my experience. Whatever works for you I guess. For me, once less component in the audio chain is a good thing. |
redfire ![]() Registered User ![]() Joined: 30 September 2011 Location: United Kingdom Status: Offline Points: 113 |
We use one of the Berri splitters in our sound, and can well recommend them..
2 in, and eight out (a direct stereo "mix" out, and six individual, gain controlled channels).. ![]() |
bosbacs ![]() Registered User ![]() ![]() Joined: 25 August 2006 Location: Philippines Status: Offline Points: 23 |
Distribution amplifier is what you need.
Thanksalot
Page <1 345 |
