MX 3000a early clip? |
Page <123 |
| Author | ||
xz_vice
Posted: 07 March 2026 at 6:20am |
How do i know the correct led sequence? Is there some kind of diagnostics procedure to follow regarding these daughter boards? Also my problem is related to the negative rail, as I tried to bypaas the gain reduction stage, and the positive rail was full, while the negative rail was clipping to the first rail (40V or so, so the second rail wasnt activating) Also, the daughter boards PCBs are burnt as hell (the back of the pcb became brown, probably because of a design issue? 😅)
I am not really experienced so I don't know how the amp works 😅, but yeah i figured out the output is the central point of the Power supply and that was really weird to me...
Greg32
Joined: 14 December 2004 Location: Australia Status: Offline Points: 120 |
Posted: 08 March 2026 at 3:25am |
xz_vice
Posted: 08 March 2026 at 6:23am |
Heyyy!! Tysm! Do you happen to have also the schematic for the big smd pcb that controls clipping, protections and so on? It'd be great 😅 It's called IC-000010-00 iirc 🤔 Also, is there a check procedure that mentions also the led sequence of the SMD driver boards? |
Greg32
Posted: 08 March 2026 at 7:29am |
uploads/417/QSC_SH-000010-00.pdf
this one, Greg
Greg32
Posted: 08 March 2026 at 7:31am |
uploads/417/qsc_mx3000a_sm.pdf
this is all i have, Greg
xz_vice
Posted: 10 March 2026 at 10:12am |
Heyyy!! Thank you so so much! Super useful! 🙏🏻 When i will have enough free time i will start investigating the issue 👍🏻💪🏻
Page <123 |
