  New Posts New Posts RSS Feed - My 18" horn, Invader Bin
 Post Reply Post Reply Page  <1 373839
parabox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote parabox Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2017 at 2:13am
ive been going back and forth  between the invader    an extended cyclops  but possibly    dragging out the path length  for more extension   or sadly bfm tuba 60s
Post Options Post Options   Thanks (0) Thanks(0)   Quote parabox Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2017 at 2:48am
 part of the problem is also flexibility     with putting horns inside witch has me considering tapped horns
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2017 at 6:05am
I had the exact same considerations, now I have 4 pcs CBe-18 & 4 pcs invaders, I didn't load the invaders yet though (you're welcome here:-)
I feel slightly embarrassed about moving so slow, yet it's not like I'm not doing anything:-)
Well, after A/B I will decide, the plan is to upscale the design to 120x80 to fit a pallet, but the 18-1500 invader has a bit too much wasted space I think...
16062024 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 16062024 Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2024 at 12:04pm
Hey there,
I just build an Invader-Bin, loaded with the Fane 18XS.
Just really roughly i used this Cutoffs :
LP Butt 18dB @35Hz ; HP Butt 24dB @70 Hz
I took around 10 measurements in my workshop with different sub and mic positions. I just wanted to get a rough 'look' at the finished work.
I really like how the bass performs for now, but I am a bit concerned about the steep rolloff at 50Hz. I want to build 3 more, so I have 4 in total.
My question now is: is there someone with a stack of 4 (or more) who has some measurments or can speak from experience on how much they go deeper in stacks of 4 (or more) ?
Im really scared to be disappointed after building so many and then realising that I wont reach 35-40Hz properly.
With all the best,
C.
Edited by 16062024 - 11 July 2024 at 8:39pm
Piato75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Piato75 Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2024 at 11:47pm
Hello,
You definitely have to use them in a stack of 4 or more and you'll reach 40hz
Curious to see your measurements even with one cab :)
immortal View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote immortal Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2024 at 12:32pm
I took some measurements of some Letterbox Invaders yesterday, unsure of the letterbox size or rear chamber volume but I will find out soon.
I could only fit 3 in the van so unfortunately don't have measurements of 4 but I will hopefully get some soon.
Blue is 1
Green is 2
Purple is 3
Orange is a reference sealed speaker with a RCF LF18G401
Setup
Cemetery Sounds
Post Options Post Options   Thanks (0) Thanks(0)   Quote Piato75 Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2024 at 11:28pm
Thanks for sharing !
Should hit 40-41hz @-3db with four
What driver are they equipped with ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Piato75 Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2025 at 3:58pm
I’ve taken some measurements of mine — SPL not calibrated, mic placed at 1m.
The Invaders are built with the original baffle with the half-circle cutout and holes, and are loaded with Fane 18XS drivers.
The response doesn’t really match the Hornresp simulation, so I might consider swapping them for different drivers as they are not horn drivers anyway.
@immortal, which drivers are you using?
