my big problem... |
wakethetown
Registered User Joined: 21 November 2006 Location: France Status: Offline Points: 12 |
Posted: 14 January 2007 at 2:55pm |
hi....
I've build a x1....but it wasn't what I hope....it's for subbass and what I need is bass ! ! ! by the way..I've done it...It's a BIG mistake....so what can I do now ? Can I put my p audio sd 18 driver on a 1850 horn or 186 horn.... I can't build a 4 ways system.... |
http://www.myspace.com/wakethetownsound
Insomnia
Old Croc Joined: 06 September 2005 Status: Offline Points: 1721 |
sell them - alot of people after x1's
and start again
wakethetown
can i put my sd 18 on a 1850 or 186 horn ?
Tom Umney
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
You got only 1 SD18? Well the 1850 or 186 horn needs to be used in minimum stacks of 4. Plus the SD18 doesn't have that large of an xmax so won't last long in either horn. So the short answer is no. Sell the SD18. |
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
The long answer: Yes
If you look deeper into the SD-18 structure you will find it's similair in structure to the 18Sound 18LW1400 and for that matter, the 18ND9300.
If you calculate the Xmax of these drivers the same way as P.Audio does for the SD-18 you will also find a Xmax of (or very close to) 5 mm.
On that hand you might want to recalculate Xmax on certain PD models aswell.
The 18ND9300 by the way, which a certain Tom Umney descripes as a PD186 beater :
I never heard of Xmax being a valuable parameter for how long a driver will last in a horn, only for how much power you can safely feed it. Hornloaded became populair in the old days because drivers of that time were short on Xmax by default (and low power amps).
With a Xmech of 30 mm oneway (IIRC) for the SD-18, it would be quite hard to get it damaged actually.
Also it has an impressive BL, which actually suggests it's an excellent driver for hornloaded applications.
The SD-18 can be seen as the crossbreed between the PD186 and the PD1850 and thus would work in both cabinets. I would however suggest to use it in the 186/1850 horn with the volume of the rear chamber between that of a 1850 and 186 horn.
Wkr Johan
Edited by mobiele eenheid - 23 January 2007 at 9:38am |
