My DIY flightcase pics (Built at home) |
Page 12> |
ape3435
Topic: My DIY flightcase pics (Built at home)Posted: 08 July 2010 at 9:30am |
Built these myself at home then shipped to Jamaica and loaded there, just thought i'd do something different as i've never built these using aluminium extrusions before.
What's your thoughts? |
ape3435
Posted: 08 July 2010 at 9:46am |
Sorry, messed up with the Pics. here goes:
http://img175.imageshack.us/img175/7236/dsc00421ly.jpg http://img101.imageshack.us/img101/2448/dsc00422yz.jpg http://img641.imageshack.us/img641/7571/dsc00423rl.jpg http://img143.imageshack.us/img143/9549/dsc00424e.jpg http://img97.imageshack.us/img97/9641/dsc00425w.jpg |
ape3435
Posted: 08 July 2010 at 9:54am |
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 08 July 2010 at 11:19am |
wow they look totally proper
ape3435
Posted: 08 July 2010 at 12:09pm |
Thanks Cravings, thought i'd give it a shot. i like new challenge, you should see my intended 5 way mid and tops box i made last year. that will be a new posting though.
Marko
Joined: 28 January 2009 Location: Croatia Status: Offline Points: 271 |
Posted: 08 July 2010 at 1:36pm |
those racks looks great!
when you do antishocking flightcase like that, what you use to fix inner and outer box? I assume it's not only foam, especially the lower (ground) junction because the foam would squeeze under the weight. Or am I wrong...? |
ape3435
Posted: 08 July 2010 at 3:18pm |
I bought a 10u shockmounted with really sturdy foam in america and load it with about 90kg, it has taken the weight so far but as i have returned to the UK i don't know what it's like now, i will ask though. To answer your question about these, i used shockmounts that i had to attach between cases as the foam that i used is only to block the space between the inner and outer case. this is sturdy foam but not enough to take the weight of the amps displayed.
you can purchase the shockmounts from different suppliers with different built to suit your needs.
Thanks for the positive comments.
taurusty
Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 504 |
Posted: 08 July 2010 at 7:01pm |
Not bad. woulda love to see the back and the speakers that these play.
Next question: Why 2 digitechs?
ape3435
Posted: 08 July 2010 at 7:46pm |
Hello Taurusty
The back is as the front but i have panels with sockets for speakers, line inputs, power input and fans (for cooling) that need to be put in place but the shippers messed up so i could not get it done, my brother will see to this.
You should see the panel i have for the console, everything that is on the mixer is on the console panel plus the power in.
The speakers i use are T18s loaded with PD1850S and my signature jbl 2226 scoop bins x 8 (started the sound with 15 inch drivers.
I flat packed some Hog Scoops and sent them to JA in the racks but as they came late i had to leave them, my Uncle is finishing these. the Hogs will be mixed with my revised version of the T18s (maybe on top, or maybe under the Hogs). the T18s will be built one beside the other instead of one top of the other.
One Digitech is for the Microphone (Looped in the Mixer = 2 mics), the other is to stagger the sampler from one column to the next.
I have another rack loaded with MX300a, etc plus another smaller console that's used for small gigs
taurusty
Posted: 08 July 2010 at 7:52pm |
Nice.Whats the name of the sound and what area it plays in, please? I'd take a ride to go listen it...
ape3435
Posted: 08 July 2010 at 8:14pm |
The Sound is Sweet Impression 9been around for 19 years come August, Crown King Sound in my area by The true Champion, Bass Oddyssey, PM me and i'll let you know where from. Where are you from and do you have a sound, what is it's name. |
Preacher
Joined: 06 February 2007 Location: United Kingdom Status: Offline Points: 1174 |
Posted: 08 July 2010 at 11:36pm |
That's a proper nice set up, top stuff!
![]() Loving the two tone blue and red panels. |
It's all about the music & the vibe, so enjoy it while you can.
Page 12> |
