My first build: THAM12 - Advice on mid/top boxes |
Page <12 |
| Author | ||
Contour
Posted: 09 August 2024 at 10:05am |
Nice job! Pretty complex crossovers it seems.
skookumsound
Joined: 05 January 2024 Location: Cascadia Status: Offline Points: 20 |
Posted: 09 August 2024 at 2:40pm |
I didn't design the crossover, and I certainly would not have attempted to build them if not for the PCBs and detailed parts list/instructions from Matt at MTG Designs. This was my first crossover build and it wasn't too difficult. I think anyone with modest soldering skills can put one of these kits together without too much trouble. Not too expensive either, and they sound great!
KDW32
Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 770 |
Posted: 09 August 2024 at 6:03pm |
Looks awesome 😎 what do you have in your rack?
skookumsound
Posted: 10 August 2024 at 12:10am |
Thanks for the reply! My rack is all second-hand gear, and I'm always looking to add more amps whenever I can afford them. I currently have a Yamaha P2500s which is powering the pair of VBS speakers, and a Crown XLS 1502 which powers my THAM12 in bridge mono mode. I also have the older RANE ME15 graphic equalizer and AC22 crossover which I was using before I built the two VBS speakers. Now I'm using the low pass filter at 100hz on the Crown amp for the sub, and sending the full-range signal to the VBS tops. I recently acquired a dbx DriveRack PA which I will use for all signal processing as soon as I learn how to use it. I'm really excited to dig into what the DriveRack can do and start experimenting with it.
KDW32
Posted: 10 August 2024 at 1:05pm |
Ahhh this makes more sense now
I have never been a fan of the sound of driverack pa. If it's first your first dsp you will definitely learn a lot of good info experimenting ![]() |
Page <12 |
