My latest mid tops - nexus-acoustics - Violence |
Page <123> |
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 06 December 2013 at 12:46pm |
Thank you, Arthur
![]() The speaker needs the following presets to obtain the final response. Low (pin 1+, 1-)
High-pass 50Hz cu 24 dB/ oct
Butterworth
Low-pass 250Hz cu 24 dB/ oct
Butterworth
Parametric EQ
140Hz, -4dB, Q=3
Low Shelf 12db/oct , 90Hz, +8 dB Gain
Mid+ high (pin 2+,
2-)
High-pass 250Hz cu 24 dB/ oct
Butterworth
Low-pass 20000Hz cu 24 dB/ oct
Buterworth
Parametric EQ
220 Hz, +3dB, Q=4
400 Hz, -2dB, Q=3
12 dB/ oct High Shelf 12500Hz, Gain
+6dB, PLOTS: Overall response with DSP ![]() Mid+ High response,NO DSP with Passive crossover ![]() Mid + High response, NO DSP, no Passive crossover, separate graphs ![]() Edited by Mircea Bartic - 06 December 2013 at 12:57pm |
andycw
Joined: 17 November 2010 Location: Norfolk Status: Offline Points: 994 |
Posted: 06 December 2013 at 12:58pm |
If you need me to run some 'tests' send a couple my way
No Bass No Fun
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 06 December 2013 at 1:21pm |
have you measured the high horns off axis to check the dispersion? i had noticed them pictured that way round on the p-audio site but was never sure which way round they should actually go.
KidCreole
Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3580 |
Posted: 06 December 2013 at 1:22pm |
hundreds per month ![]() |
Mircea Bartic
Posted: 06 December 2013 at 1:26pm |
We did off axis plots for testing but didn't save them the 60x40 degree dispersion can be matched by the mid horn. Yes , we saw that too, so we asked P-audio directly and they confirmed us that that is the corect placement. It goes against everything I know about horn design but they are right. Edited by Mircea Bartic - 06 December 2013 at 1:28pm |
cravings
Posted: 06 December 2013 at 1:37pm |
looking again the pic is back the other way on their data sheet (link), but they show a box on their front page with this horn as you have it.
very confusing. i agree it looks totally wrong.. i make no claim to understand horn design but comparing it visually to many other horns of known dispersion it seems backwards. |
ArthurG
Joined: 03 May 2004 Location: France - China Status: Offline Points: 988 |
Posted: 06 December 2013 at 2:27pm |
Great Job Mircea ! I see that you apply a big EQ on the 2 extremities of the spectrum, but seems logic when you look at your HF (deep) horn and the sensitivity of your MHF section. Otherwise, your EQs in the mid bands are very limited to get a flat response, meaning that your acoustical optimization is well done ![]() What's the size & weight of this cabinet ?
Looking at my production plan, I exaggerated a bit, real number is close to hundred per month (average), spread over 3 customers, covering North America, Africa, Europe and Asia. However, I don't want to hijack Micea topic so I won't post a link here
KidCreole
Posted: 06 December 2013 at 2:48pm |
Start a fresh one then
cravings
Posted: 06 December 2013 at 3:11pm |
agree they look like great boxes, really useful. sorry for derailing the thread into a p-audio discussion!
VentureSound
Joined: 18 October 2009 Location: London N20 Status: Offline Points: 949 |
Posted: 06 December 2013 at 5:08pm |
Just another point about the dispersion thing... My EV CD horns are 60 x 40 and in the back of the horn there is a vertical slot. With the slot in that position (vertical) the horizontal is 60 degrees dispersion.
Have a look here... http://www.electrovoice.com/product.php?id=32 In the third picture you can see the horn throat and its vertical slot. That is as they come from the factory and its 60H. |
Mircea Bartic
Posted: 06 December 2013 at 5:54pm |
There's no use in discussing the position of the HF horn. P-audio R&D confirmed it was correctly rotated for the 60 degree horizontal dispersion as odd as it may look.
Mircea Bartic
Posted: 10 December 2013 at 7:28pm |
I prepared some pictures for the final product.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() You can see a lot of my earlier projects on my facebook page https://www.facebook.com/nexus.acoustics.research |
Page <123> |
