  New Posts New Posts RSS Feed - My new Scoop design
My new Scoop design
Joe Jones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Jones Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2006 at 8:04am
Originally posted by Contour Contour wrote:
Hello Jones,
Very strange, every time I read a post by you it reminds me of a Bill Fitzmaurice post. Same use of language and so on. But I assume you are not the same person.
Best regards,
Walt
The comparison is most flattering, thank you, but alas I am not he. I'm Batman.
minaximal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote minaximal Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2006 at 9:16am
Originally posted by tb_mike tb_mike wrote:
 The question is it audible?
exactly, and with accumulated compromises with horn design, its best to try and minimise these, so theres no harm in trying.
although i dont see how it will help much in a scoop for upper band frequency response due to the pathlength differences from the direct radiating element and rear horn loaded. (42cm you say eh!?)
the modulation thing was from the bass modulating the upper freqs of divisable wavelength, but i cant remember where i read it..
its not my thing, but as mykey insinuates; people who like scoops will probably like the "dirtyness" of the sound this would produce.
howd it go mykey?
Edited by minaximal - 01 March 2006 at 9:17am
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2006 at 11:16pm
should be finished this week, ill let you know.
and if it doesnt work???
does anyone want to by a smooth curved wheel barrow?
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2006 at 9:57am
Well, if it doesn't work, it might still be usable by lining the curves with sound deadening material - this might reduce the transmission of higher frequencies through the horn path.  Could be worth a try rather than relegation to firewood..
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2006 at 4:47am
tighter than a chinese virgin
as fast as an Aston Martin
as low as a tramp sitting on a park bench in the rain
Post Options Post Options   Thanks (0) Thanks(0)   Quote minaximal Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2006 at 5:10pm
i dont know how tight a chinese virgin is, but i did go out with a japanese ex geisha for a while, as to the rest, technical stuff then!?
hows the 100hz region?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2006 at 1:00am
when played at full range, the mid is quite exceptional (effortless)
though some one did mention that would happen?
all it needs is a tweeter above.
ill put some pics up soon
at the moment the cab width is 580mm im increasing it to 610mm.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2006 at 6:42am
ill be crossing them over at 80.
a sigle 15  x-tro will go above
i like the way your thinking mykey!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2006 at 6:45am
Originally posted by djstefanos djstefanos wrote:
 no offence, looks like a toilet
i thought that was what he meant with for a different kind of bottom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2006 at 6:51am
scoop with a tweeter on top. actualy alot of bass guitarists [ok a particular group but a reasonably sizeable one] with particular playing styles would bite your arm of for such things. i think scoops have got a fair few more uses than peeople like to admit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 4:17am
some build pic's
inside the throat..
and the scoop.
Notice that it has no brace at the mo the 2 sides were vibrating like rubber bands, and the baffle is machined out for a pd the hexagonal shape but i dont have a pd so i had to put a different baffle in front and use this 19'' im trying out.
Edited by mykey - 20 March 2006 at 4:19am
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2006 at 3:21pm
What driver is that in there? Looks like JBL or P.audio.
