  New Posts New Posts RSS Feed - My new tops
My new tops
singingfish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Topic: My new tops
    Posted: 30 April 2019 at 8:03pm
These are the fruits of my thoughts and labours over the last few months
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2019 at 8:05pm
..powered from this rack
cuivenion View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote cuivenion Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 3:06am
Wow, it's become very quiet on this forum nowadays. They are very, very nice cabs.
help!!!!!!!!!!
partya View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote partya Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 4:44am
Very nice, are they a 15," 2 x 6.5" + a CD???
Keep up the good work!
Turn it up! Turn what up?
Old king coles View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Old king coles Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:36am
looking good my friend
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 6:49pm
They're
1 x EV DVX 12" woofer, horn loaded
2 x EV/B+C DVN265 Neo Midrange
1x EV ND2 compression
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:01pm
I built the hf array from midrange waveguides from EV DVX Line array cabs. I cut these in half and sandwiched around my ply Horn carrier. The Horn Carriers house generic 60 x 60 CD Horns which I butchered and shortened as I wanted a narrower 70 x 40 degree pattern. The Comp horns only have to go down to 4k so I shortened them quite a bit and fixed with epoxy into the ply with a ply reinforcement to carry the ND2 comp driver more sturdily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:07pm
THese are the rather nice drivers I found for the mid top arrays.
I had to re cone one of the B+C mids, which was an education for me.
This pic shows how I epoxied it all together after bandsawing the Mid guides in half carefully
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:09pm
I made these phase plugs from aircraft spinner cones mounted on to ply stays to raise the top end of the mids some more up to nearly 5k.
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:10pm
and some 4mm shims to make sure the drivers don't strike the plugs
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:11pm
hah!
these shims.
(still getting the hang of posting pics)Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingfish Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:14pm
so they mount here
Like this
and set about it with car filler and black.
