  New Posts New Posts RSS Feed - My set up! Help!
My set up! Help!
Chewit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chewit Quote  Post ReplyReply Direct Link To This Post Topic: My set up! Help!
    Posted: 23 May 2020 at 12:43pm
Right so Iv got my stack together!
2x scoop loaded with
FANE XB 1000wWink
2x reflex loaded with
eminence deltas 400w
2x MT121 loaded with
B@C 12PE32 12" 250w
P-Audio BM-D450 MK2 1"
Been Researching and learning about amps and the crossovers!
This is what Iv put together
Scoop -
BUT48 : BUT24
HP/35hz
LP/65hz
Reflex -
BUT24 : BUT24
HP/65hz
LP/150hz
MT121
12inch -
L-R24
HP/150hz
LP/1khz-1.2khz
Compression -
L-R12 1khz
L-R12 20hz
I’m not to sure on this and still figuring it all out as new to this! Any help would be amazing!!
Edited by Chewit - 23 May 2020 at 12:44pm
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 1:39pm
Those crossover points and slopes look OK. I might cross the compression driver a bit higher though. The BMD450 isn't very good below 1.6kHz, and you will want to put the biggest horn on it you can get. If you cross it in at 1kHz on a horn that's too small, you will get bad distortion problems (a harsh sound in the upper mids).
Really, a 1.4 or 2" driver on a large 800Hz horn is a better match for the MT12 horn. The MT12 only has 60 degree dispersion up to about 800Hz, thereafter it narrows.
Also remember that the BMD450 response isn't even as flat as it looks on P Audio's graph, so you will want to use a PEQ to cut quite a lot at about 3kHz, in order to not have your hi-mids overwhelm the rest of the range. In fact this applies to most compression drivers. A lot of new users don't do this, and wonder why their rig sounds harsh....
This page was generated in 0.059 seconds.
