My SMT212 CP755TI / SN12B |
Page <12345 9> |
roborg ![]() Registered User ![]() Joined: 05 July 2004 Location: United Kingdom Status: Offline Points: 1026 |
nice cabs, i used the same drivers in my mid-tops. Are u gonna use your cabs in or around London soon, be nice to hear them? Those sn12b's are seriousaly nice drivers, even nicer with a phase-bung
![]() I reckonned i spent 800quid a pair, so a very cheap cab for their performance.:
![]() ![]() ![]() cheers,
Rob.
hehe that cab got a bit mangled
login4 ![]() Old Croc ![]() Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
![]() did you ever do an A/B comparison one with phase plugs one with out? ye i really like the SN12B's, very solid sounding and a bit of a steal if you ask me wafflesomd, what Compression drivers will you be using? Edited by login4 - 21 August 2008 at 11:07am |
CELTIC SUBSONIC SOUND SYSTEMS
hi guys,
if anyone is interested ill be taking out the SMT's this weekend to: Grass roots festival (muddy promotions) http://www.thegrassrootsfestival.co.uk/ the festival is held near peterborough and ill be on the Circuit Tree stage, come have a listen it would be great to meet some peeps off here... |
jonny4288 ![]() Registered User ![]() Joined: 06 August 2008 Location: N.Wales (WXM) Status: Offline Points: 586 |
just noticed you had them at workhouse festival, only 40 mins down the road from me.
you doing anything else local soon, im stuck on what im going to use for midtops for the rig im putting together, would like to listen to a few differnt tops to get an idea of what will compliment the rig best.
x1 letterbox with 4 hd15's and 1 or 2 midtops per stack. just building the 1 stack for now though.
will mainly be used outdoors in ruthin/denbigh area (clocaenog forest)
hi jonny,
iv been to some good woodland events up there ![]() im not sure when the next time ill be up that way but ill be sure to drop u a pm if i do. in your system id say something fairly small like a porn horn type cab should do it, i haven't tried my SMT212's above a kick section yet, i dont feal they need it but ill look forward to the results. last outing the other week: ![]() (fish eye) ![]() |
wafflesomd ![]() Young Croc ![]() Joined: 21 September 2007 Status: Offline Points: 811 |
I havn't decided. I'm currently searching for drivers on a budget for these cabinets. I should have built some X12's. It's hard to find a driver for cheap that will work well in these. |
perhaps a p.audio BM D740, 1.5" exit
djstefanos ![]() Old Croc ![]() Joined: 18 November 2005 Status: Offline Points: 2355 |
do you have issues with balancing when lifting up from the flush handles?
Deadbeat ![]() Old Croc ![]() Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
wafflesomd, try selenium as well for comps.
Edited by Deadbeat - 03 November 2008 at 8:25pm |
Away on extended leave.
they are a little top heavy with that monster comp driver in but its not too much of a problem as i put another handle on the back of them too this also helps for going up stairs as the one going up first can grab the handle with one hand. i would advise putting the side handles a little higher than i did. |
Do you think that P.audio will keep up with two Emeinence Delta's?
Page <12345 9> |
